Curious Noise When Opening Door
Discussion in 'Prius c Main Forum' started by Lickmeister, Aug 4, 2012.
  1. Lickmeister
    Lickmeister New Member
    Has anybody else noticed a noise that begins upon opening the passenger door? It lasts for about ten seconds then stops. Is it by chance a battery ventilation fan or something related? Just curious.
    51,828
    brake accumulator. it's in your manual.
  3. fuzzy1
    10,393
    None of my passenger doors trigger the brake accumulator. Only the driver door does that.
  4. Lickmeister
    I originally meant to say driver's door.
    Bisco: Can you give me the page number from the manual where it mentions that. I looked but can't find the reference. Thanks.
  5. bisco
    51,828
    i'm sorry lick, i don't have a 'c'. i'll see if i can find the heading/chapter.
  6. bisco
    51,828
    in the pip manual, pg.42, under 'plug in hybrid system', section 1-1 'before driving', 'sounds and vibrations specific to a hybrid vehicle', 'the brake system operation sound heard from the front of the vehicle when the driver's door is opened'.
    hope this helps!
  7. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    It's like a buzzing nose? Lasts like 5 seconds if that. I believe is normal.
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Is it the same noise if you pump the brake pedal a few times?
  9. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    I think so. It makes the same noise when I enter it too and when I leave.
