Making Arrows Vanish
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by airportkid, Jan 5, 2006.
  1. airportkid
    airportkid Will Fly For Food
    2,191
    538
    San Francisco Bay Area CA
    I've seen numerous posts referring to "coasting" or "gliding" with an arrowless energy display - but I either haven't figured out how to "feather" the throttle to attain this Zen like display or the software in a late '05 Prius no longer permits such a representation. If the wheels are turning, my Prius will show arrows, sometimes the whole quiver all at once. Which makes sense. If the wheels are turning, the energy is kinetic, and it's either going from the wheels into the battery, or the synergy drive is turning them. The only time, logically, that the arrows would be absent is when the wheels are stationary.
    So is an arrowless display while in motion actually possible - or have I misunderstood all the posts?
    Mark Baird
    Alameda CA
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    It's possible, but takes time and practice.
    Try this next time you're out and can mess around without risk to other traffic or pedestrians.
    Once the car is nice and warmed up and you don't have the AC working too hard and you're sure the defrosters are off start a nice smooth moderate acceleration up to 39mph (no faster) on a flat stretch of road. Quickly lift your foot completely off the gas pedal for about 1/2 to 1 second so that only green arrows (regen) from wheel to battery show and the ICE shuts off (if the radio is off it will help you hear it, but you should be able to 'feel' it too).
    Now, very carefully and slowly reapply pressure to the gas pedal until the green arrows disappear and hold that position. You shouldn't have much trouble with that. Getting a no arrows condition at any speed over 40mph is very very difficult...but even that can often be done with practice.
  3. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    After the SOC is sufficient on the HV Battery you may let your foot off the accelerator and then very gently just touch the accelerator pedal until you get a no arrow condition. Simple right? However sufficient SOC is variable and generally requires at least 10-15 minutes warm-up. This no arrow or free wheeling so to speak will only occur with a green or purple battery state, signifying a proper state of charge. During a nice Sunday drive this is easy to obtain especially with nice downhill sections. If you bring the Prius up to a coast and then throw it into neutral you will duplicate the no arrow condition. In doing this, for some reason does not seem to appreciably add to MPG. I'm convinced its detrimental to MPG ( by coasting in neutral) Why this is so has not been addressed by our experts. The consensus is however that putting the car in neutral will not hurt it, niether will returning the car to drive.
  4. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    It is not easy. If it was everyone would pump their tires to 60 psi throw out the spare and rear seat and get > 100 mpg. First try this, after the car is warmed up (easy in your neck of the woods) hit the B mode. You will see no arrows. Go to drive. Accelerate to the speed limit or if you dare 3-5 over and take your foot off the gas. You get the green arrows. Let that go for 2-5 seconds. It needs a bit of time. Slowly and gently (you have a raw rotten egg between your foot and the accelerator if you crack that egg your car will be unusable for 5 years ). If you get yellow arrows to MG2 back off just a bit. No arrows you are gliding. The car must be warmed up to above 70 C. The next part is harder much harder. I am still working on this. When you accelerate press on the gas until there is power to the wheels from the ICE with or with out power from MG1 to MG2. Nothing to or from the battery. If you are getting flickers to and from the battery that is OK to start with. I try to stay away from sustained (several seconds) of battery to MG2 and am willing to accept some charging. Dead banding is really tough. Work on it. You can get a ScanGage or CAN View to help you get a handle on when the ICE is running and when the ICE is up to temperature. Fun, Fun, Fun. :D
  5. andyprius
    2,212
    188
    The Dr beat me to it, thanks Evan
  6. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Every one is chiming in. The slight down hill is a good addition to start with.
  7. andyprius
    2,212
    188
    But not found in Alameda!
  8. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    You live in SF so it will be difficult to get "no arrows" in the city. Going downhill will still get you recharge arrows. If there is a more level area that you drive try it there. You really have to get a light foot and even then the arrows will not last for more than 20-30 seconds at a time (unless you are on some very level but very slightly declining road (which does not exist in your area!)
  9. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    I would also say that you're probably going to find "deadbanding" to be difficult there as well. Deadbanding is pretty easy to achieve on flat ground as long as you don't try to accelerate to briskly. Frankly I wonder how effective it really is, particularly if you're going to encounter situations where regenerative braking can help replenish the HV energy you consume by demanding a little more power from the car. It seems to me that if deadbanding is going to get you up to cruising speed at a somewhat slower pace than moderate acceleration w/battery assistance then overall you're not going to see an increase in MPG. In fact, if the discrepancy is big enough, you'll see a drop in MPG. Not that deadbanding is to be avoided at all costs either. There are times when it makes sense.
  10. driveprius
    driveprius New Member
    112
    Delaware
    The easiest way to experience the no arrow state is to:
    1) Make sure your engine is fully warmed up. After 10 minutes of driving this should be enough.
    2) Make sure you have no red bars on your battery.
    3) Find an area where the speed limit is 45 mph or less and your in a slight downhill. The steeper the downhill the easier.
    4) Get your speed so that it is no more than 40 mph and it is safe to do so.
    5) Lift off the gas and allow your car to coast with green arrows going to the battery. This is coasting like a conventional car as your Prius will tend to slow down with engine braking.
    6) Now press the gas down just slightly until you see the green arrows go away.
    7) You should either see no arrows or possibly a momentary appearance of yellow arrows from the battery to the electric motor.
    8) If you see the yellow arrows, wait about 2 seconds to see if they go away. If not just back off the gas pedal just enough to make the yellow arrows go away.
    The no arrow state is the tiny sweet spot in between having the green arrows appear and the yellow arrows appear. When you drive 40 mph on level road or downhill it's easiest to achieve.
  11. TorontoSusan
    TorontoSusan New Member
    44
    Toronto, Ontario CANADA
    It takes a bit of practice: I too have a late 2005 and I tried this technique after reading it on the board. It does work but it needs a very light touch on the accelerator - very light. I can do it - esp if I've got a good speed and I want to glide. For me, the key is to get it up to speed and then lightly touch the accelerator pedal until the arrows disappear .. use if often on a slight downgrade coming home from work.
    Keep trying ... it's neat! and yes, the 'no arrows' will show up on your monitor.
  12. geologyrox
    geologyrox New Member
    513
    a long extended stretch of flat (or, i suppose, a slight downhill - steep just seems to make the batteries charge) seems to be ideal to figure out that point that you need to find. You'll be able to do it better on less ideal surfaces if you can get in some practice somewhere perfect. It's been described many times, but heres a new Prius Driver observations:
    First, get to the speed you want to coast down from - around here, the speed limit is about 40, so I go up to about 45. It's pretty difficult to get it to work above 40ish, but I always try. I take my foot off the gas as far as I need to to get into regen - green arrows from the wheels to the motor to the battery. Then I apply a tiny bit more gas - just until the arrows change, and very slowly. Sometimes I've gotten it in just fine, and the arrows all disappear. The car slows down kind of quickly in regen, but the car maintains it's speed much better with no arrows - even later when you can get it to do it up a hill. Most times, though, I apply just a bit too much gas, and the regen arrows switch directions and turn yellow - I'm using the battery to power the motor sending power to the wheels. If you hit yellow, don't worry - just lift up a tiny bit, very slowly - the arrows should disappear. You may 'overshoot' it again - just keep going to green, then yellow, and back - try each time to be a little bit slower.
    You get pretty good at this pretty quickly - learning on good flat ground means you get good at it, and then can use it on the hillier portions. Good luck!
  13. airportkid
    2,191
    538
    Many thanks for all the insights and instructions!
    Of course, right after I posted the original question, I tried again and (magic!) managed to make the arrows disappear. This is the usual outcome of making any sort of claim - the next action refutes it.
    But all your comments are nonetheless helpful. Thanks again!
    Mark Baird
    Alameda CA
  14. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    With regard to the suggestion that deadbanding doesn't help MPG.
    Consider that changing energy from one form to another has inheritant losses, usually in the form of heat. So if you are going to stop, if you can glide without regen as much as possible, you lose less to regen.
    So, if because of friction and drag you could slow down from 50 to 20 in 1000 feet, start deadbanding 1000 feet from the stop.
    As for deadbanding for acceleration, I don't see that possible, even if by deadbanding you mean accelerating with ICE only. MG1 has to either give or take a force in order to get ICE's power to the wheels, and usually it would act as a generator to do so. That generated energy is best going completely to MG2 rather than going to the battery.
    By the way, I know this may sound counter intuitive but it has been determined using the miniscanner on a classic that at cruising, the car actually takes power from MG2 and sends it to MG1 to emmulate overdrive.
  15. Kiloran
    Kiloran New Member
    1,225
    I want a "Glide" button on the steering wheel that would force gliding without the hassle and restore "D" gear when released.
    Or, better yet, allow me to set an option where there is no regen unless braking or in "B" gear so I can easily choose when to regen.
    Edit: Changed "Coast" to "Glide" and "deadbanding" to "gliding"
  16. efusco
    19,891
    1,196
    Nixa, MO
    Just for clarification of terms:
    Dead-banding--refers to the ICE-only (no arrows to or from the battery) driving
    Gliding--refers to the no-arrows condition on the Energy screen when coasting with slight accelerator pressure to eliminate regeneration. FWIW, Even when gliding there is some flow from the battery to the wheels...albeit a small amount--usually in the range of 2-6 amps. It's just not displayed on the Energy screen.
