Smart Key Stopped Working After Replacing 12 Volt Battery
Discussion in 'Gen 2 Prius Main Forum' started by NYPrius1, Aug 8, 2012.
  1. NYPrius1
    NYPrius1 Active Member
    1,181
    125
    Middletown, NY
    A purchased a new 12 volt battery at the dealer. I was getting weird warning lights, so I had them run diagnostics. They said all the codes were voltage and I needed a new battery.
    Shortly after this I noticed the Smart Key no longer opened and closed the doors.
    The car starts ok.
    My question is this, could the changing of the battery have caused this?
    I tried searching for the answer BUT all answers refereed to adding a new smart key purchased on Ebay.
  2. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    The most likely cause you be that they pressed the "key" button below the steering column. You may want to press the "key" button once then start the car, turn the car off, remove the key from the slot and see if it works.
  3. NYPrius1
    1,181
    125
    Middletown, NY
    Thanks So Much for the reply.
    I tried that, no luck. When I pressed the button It did stop the car from starting with out the SKS inserted.
    I pressed the button again and it starts without the SKS inserted
    It's just that nothing happens when I hit lock or unlock.
    I was thinking new battery for SKS, But this started with the change of the 12 volt battery.
  4. Avi's Advanced Automotive
    776
    363
    Does this happen with both keys?
  5. NYPrius1
    1,181
    125
    Middletown, NY
    Yes, Neither one will open or close doors.
  6. Avi's Advanced Automotive
    776
    363
    Sound like time to head back to to dealer for them to fix it.
  7. NYPrius1
    1,181
    125
    Middletown, NY
    I just noticed that the small red light doesn't blink when I press the keys.
    On our 2010 the light blinks when you press the lock or unlock buttons.
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Then, it's likely the battery inside the fob is dead.
  9. NYPrius1
    1,181
    125
    Middletown, NY
    Thanks for the reply. I will try that.
  10. NYPrius1
    1,181
    125
    Middletown, NY
    Just got back from Toyota, They put in new battery in the SKS. Everything working Just Fine! Charge $4.00 Including Sales Tax or 8 3/4 %.
    Thanks for the help guys
  11. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Those batteries (CR2032) can be had for ~$1.79 at Fry's Electronics around here.
    There's one place online that sells that for MUCH cheaper than that, but one has to order a bunch to make it worthwhile, due to shipping costs.
  12. NYPrius1
    1,181
    125
    Middletown, NY
    I am sure when you add the S&H it will come to 4.00.
    Also, the labor charge What's the rate at the dealer for 5 minutes labor. LOL
  13. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    The CR2032 battery in the fob is pretty easy to change.
  14. Salvage09
    Salvage09 Junior Member
    Pasadena CA
    FWIW, 'Dollar stores' often sell LED votive candles @2-3/$1 and they're powered by....2032 or similar batteries.
