It Just Drives Me
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bilofsky, Aug 19, 2012.
  1. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Unnecessary. Even while moving, if you just lift on the brake pedal and reapply, all will be well. The TC light can still be flashing even. It only limits braking to friction immediately after the TC kicks in until the next de-assertion of the brake pedal.
  2. Even more interesting. What's TC ?
  3. bisco
    51,799
    traction control.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    As bisco said, Traction Control.
    And it is confirmed by reading the CAN output of the Battery ECU and you can see the charge going in and out.
  5. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    LOL yes I know someone must own it but it was some weird deal that the city tried selling the land to cornell for a dollar or something. I really dont know enough about it but the bottom line is that the road sucks and i always get bumped out of regen going down it when it is prime down hill for recovering ev power.
  6. Jimbo69ny
    712
    107
    Ithaca, NY
    You dont understand. The whole section is crap!!! I would be kicked out of regen every second. I should post a video.
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    But you don't have to put it in park to "reset" it like you said you were doing earlier.
    I know what cobblestone is. Yes you will be kicked out of it. You will just have to use friction brakes or slap it in B mode.
  8. Jimbo69ny
    712
    107
    Ithaca, NY
    But I dont want to use friction bakes and B turns on the gas engine. My whole route can be done in all electric as long as I regen on the way down.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    So you actually stop on the road every time you're kicked out of regen braking, put it in park, then D and drive on? This is silly.
  10. Jimbo69ny
    712
    107
    Ithaca, NY
    Did you read my post? I said there were 4 stop light/signs on the down hill. It takes nothing to hit P then D when your already stopped. That way I at least get some regen on the next jaunt before I get kicked out again.
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    he's a redneck, whatta u expect?:ROFLMAO:
  12. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    But if you stop in D, you will have regen again as soon as you start. There is no need for park...
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I'm not, I'm just surrounded by them lol
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    ah......ok
  15. Jimbo69ny
    712
    107
    Ithaca, NY
    Is that true? It wasnt true with my 08 according to my Torque app.
  16. Jimbo69ny
    712
    107
    Ithaca, NY
    So the big question is, when regen braking is bypassed, how long or what conditions have to happen before it is reactivated?
  17. Jimbo69ny
    712
    107
    Ithaca, NY
    Priuskitty, stop being catty.
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    kant.......it's my nature:D
  19. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Oh, that regen. I'd been wondering how that could apply.
    Is there an indication that regen is off, other than the Charge bar not extending?
  20. Jimbo69ny
    712
    107
    Ithaca, NY
    Not without a Scangauge or Torque app.
