What do you use to clean your displays?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jimbo69ny, Aug 22, 2012.
  1. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    I have a pip and displays out the wazoo.
    Heads up display (HUD)
    Display on top of the dash
    7" Nav display
    What do you guys use without scratching them?
  2. Buzzhead
    Buzzhead Non-Interference w/ devel of pre-Warp civs
    151
    59
    Chelmsford, MA
    The '10 may not be as sensitive, but I use a dry microfiber cloth to get the dust off, then one dampened with water to clean the smudges off the Nav screen. No experience with the HUD - wish I had one.
  3. Jimbo69ny
    712
    107
    Ithaca, NY
    BUT you have a sunroof and solar panel option. I could say the same thing to you. :p
  4. El Dobro
    El Dobro A Member
    7,088
    3,270
    I use a cloth that's made for wiping off musical instruments.
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I bought a box of eye glass cleaner wipes at Costco for under $10 (for several hundred). Works great, and should last a lifetime... :D
    edthefox5 likes this.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Yes camera or eyeglass lens cleaner tissue and lens cleaner solution.
  7. DB-n-NorCal
    DB-n-NorCal New Member
    Sf Bay Area (Northbay)
    Hi all, thought I might throw in my 2 cents since I have received so much good information from this board.
    I found Notebook Computer Monitor wipes work very well and don't scratch or smear as long as they are not too wet and they are anti-static which means the area you clean will resist attracting dust. These are available at any computer or office supply store as well as online at Amazon. You can get them individually packaged or in multi-count containers.
    car78412 likes this.
  8. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    I use the little foil packs of Zeiss lens wipes. I bought a box of 200 at Sams club for a few $$. I put a dozen of the little packs in the top glove box beside the maps. Tear open the pack, wipe my glasses, then wipe the radio / HVAC display panels, it cleans, removes scratches and cleans to the point that dust is less apt to stick on the clear plastic. Very happy with the results on a 3 year old Prius that had some scratches on the display screens from dry wiping and seemed to be dust magnets. They are still clean and look great after Sundays 500 mile trip.
  9. Andrax
    Andrax Junior Member
    I have a 2010 IV that I picked up a couple months back and the display to the right of the HUD where you can view fuel economy in 1 min or 5 min intervals and it has a plastic cover over the actual display.the previous owner somehow managed to get smudges on the INSIDE of that panel. No idea how to clean it sadly.
