Viper SmartStart & 2010 Prius?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Que1999, Jul 25, 2010.
  1. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Would u be able to get the wiring diagrams from ur installer at Best Buy?
  2. exbauer
    exbauer Active Member
    1,188
    102
    Washington
    I am thinking about getting the VIPER VSS3000 installed. The difference between the VSS4000 is a 4 button remote. Seeing that I will be using my iPhone I don't really need it. Best Buy seems to be selling the VSS3000 for $299.99 and VSS4000 for $399.99 with Geek Squad installation. I wonder what other charges there will be. I'll call them up tomorrow to see.
  3. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    does it come with the keyfob too ?
    so everything included with the install for $299 ?
  4. exbauer
    1,188
    102
    Washington
    I don't think that is the final price. There is probably a bypass module also that is not included. I am going to give them a call tomorrow and find out what the total would be. It would be nice if it is $299.
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Besides the bypass module, that price includes the viper alarm system & the viper smart start module?
  6. exbauer
    1,188
    102
    Washington
    Yeah, I went to Best Buy today and depending on which model you get it is $299.99 for the VSS3000 and $399.99 for the VSS4000. It includes the Viper remote start with SmartStart. Then you need to purchase a bypass module for $169.99. So, for the Best Buy in Mission Valley in San Diego the total would be $470 + tax installed for VSS3000 and $570 installed for the VS4000.
    Viper VSS3000 SmartStart Remote Start System and Geek Squad Installation
    Viper VSS4000 Remote Start System with SmartStart and Geek Squad Installation
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I'm assuming that u already have a viper alarm since this is just the Viper smart start module?
    Or am I missing something?
  8. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    I used my smart start today. In Cleveland there is an area called Tremont that has a lot of trendy restaurants located in a very old neighborhood. The have an event called the Taste of Tremont. It was 90 deg and we had to park about 1.5 miles from the event.
    I pulled out my cell phone, ran the apps and started the car while we walked. When I got to the Prius it was a cool 72 deg in the car. It makes the extra money you spend worth it.
    peterjmc likes this.
  9. exbauer
    1,188
    102
    Washington
    It isn't an alarm. It is just a remote start. If you want an alarm you have to get the VSS5000 that is an alarm and remote start. Another way is to get an Viper alarm and remote start that works with SmartStart.
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Oh.......so u only need a vss3000 or vss4000 & a bypass module? The alarm part isn't needed?
  11. peterjmc
    917
    189
    Clarksburg, MD
    Correct. The alarm component is not needed.
    sfv41901 likes this.
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Thx.....good thing i didbt buy the alarm part :D
  13. Judgeless
    1,821
    257
    Cleveland, OH
    I have the alarm part also. The car finder is a nice feature. It is loud.
  14. wsbsteven
    wsbsteven Prius owner gone Leafer
    24
    Saint Louis
    I was told 300-500 in addition to the smart start plus I loose a key and void my warranty. Wonder why
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Who told u this?
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
  17. wsbsteven
    24
    Saint Louis
    The bestbuy installer. I know about the act you posted but I was surprised to find my experience was different than other members. I'm going to try another best buy to see what they say.
  18. Judgeless
    1,821
    257
    Cleveland, OH
    I am surpised that they told you that. The Best Buy near me had the bybass module in stock. it was called FLCAN by Flash Logic. They program it for your car on the PC in the service center. You do not need to give up a key.
  19. wsbsteven
    24
    Saint Louis
    I picked up a VSS3000 today from Bestbuy (not installed yet, that is next weekend) and I have the FLCAN. I was told no pitstop mode since it's a push to start. I was also told if I open the door, the engine will shut down. I hope this isn't true but I was told not to think it would do otherwise.
  20. Judgeless
    1,821
    257
    Cleveland, OH
    It is true that the car will shut down if you remote start the car and then open the door. I have remote start set for 60 minutes.
    I use pit stop mode all the time. It works perfect. Mine is set to 60 minutes. The car will not shut down when you open the door in pitstop mode. When you press the brake pedal the key fob will play a short jingle to tell you pitstop mode is off. The car will keep running.
    I also have to set to auto lock the doors after 20 seconds. I also disable the arm disarm chirp from the viper unit. It uses the OEM chirp the car already makes.
