oil filter wrench???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mrporsche, Aug 31, 2012.
  1. mrporsche
    mrporsche New Member
    I find the oil filter to be the most difficult to remove of any car I have worked on. What kind of oil filter wrench do you find satisfactory?
  2. gmcneil05
    gmcneil05 Member
    118
    36
    Avon Park, Florida
    Big pair of channel locks. Then just hand tighten.
  3. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    I bought from a Toyota dealer a cup-shaped tool that fits onto the bottom of the filter and has a square hole in the middle for a ratchet. It works great. Don't over tighten the filter when installing. Good luck!
    HaroldW likes this.
  4. Patrick Wong
    18,200
    6,491
    Exactly. This is the best tool for this particular job.
    Alternatively, bring an oil filter with you to your local auto parts store and find a cap wrench that has a good fit on the filter. Do not buy a cheap wrench made of plastic.
  5. AzWxGuy
    AzWxGuy Weather Guy
    1,028
    517
    Tucson, AZ
    2021 Prius
    Autozone has an OEM Oil Filter "F" Cap Wrench for a couple bucks. The tool lists some of the filters it will fit on the inside, including the Fram TG4967 that I use. Makes oil changes a breeze.
  6. Mike500
    Mike500 Senior Member
    2,593
    766
    The one at Autozone, unfortunately, doesn't fit. I returned it.
    This one fits perfectly.
    Amazon.com: Lisle 54930 65 mm Flute End Cap: Automotive
    That's my picture with the filter cap on my Prius"v" that I posted.
    If the dealer overtightened it, be careful, it can break.
    This one is stronger.
    Assenmacher Specialty Tools TOY 640 Oil Filter Socket Wrench for Toyota/Lexus : Amazon.com : Automotive
    If you want the best, get the OTC made service tool.
    Toyota OIL FILTER WRENCH Part Number 09228-06500-02
    I have all three.
  7. Patrick Wong
    18,200
    6,491
    Note that Classic and 2G use the traditional oil filter which has its own metal shell, vs. 3G which has an oil filter that is just a cartridge. Hence the tool required to remove the 3G filter cap may be different than the tool required for the Classic/2G oil filter.
  8. Mike500
    2,593
    766
    I've own this Lisle filter wrench for nearly 20 years. It still works for removing the stubbornest and tightest metal canister filter.
    The harder that you turn the wrench counterclockwise; the tighter it grips. I've NEVER not been able to remove a filter using the wrench.
    With the Fram "grip" coating, a lot of cap wrenches dont fit the end of the metal canister. You shouldn't be using a wrench to tighten it, anway. Unless, you have carpal tunnel.
  9. Mendel Leisk
    40,492
    <deleted, may not be applicable to 2nd gen>
