Contribution of MG2 and ICE to output Torque
Discussion in 'Gen 2 Prius Technical Discussion' started by James Goss, Jul 18, 2012.
  1. James Goss
    James Goss New Member
    Hi Everyone,
    I'm wondering if you may be able to help. I need to make a simple estimate of the output torque of MG2 in the Prius II over the UDDS, HWFET and US06 driving cycles. The rpm of MG2 is simple to calculate as it's directly coupled to the wheel speed. I know that the torque will depend quite significantly on the battery SoC and I'd be happy to assume that it starts at 50% or similar. The attached image shows the 'optimal' operating line that the ICE is worked at but as the ICE speed seems to have little correlation with vehicle speed it's difficult to pick out where the ICE is operating and hence what is torque is required from MG2 to meet demand.
    I don't want to go to the lengths of trying to reverse engineer and model the control strategy of the vehicle as they've done here, as that's quite outside the scope of the project.
    Does anyone have any ideas?
    Also does anyone know how MG2 combines with frictional brakes to provide the braking torque?
    I'm currently assuming MG2 recovers anything up to 250Nm after which the frictional brakes take over.
    Many Thanks
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    What exactly is your project about? If I were you I would just use your 2006 Prius to collect data for the driving cycles as a start. The experiment must have been done by some labs but I don't know if the data would be available to us. Sorry can't be very helpful.
  3. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    2017 Prius Alpha
    James:
    I've been off the forums for awhile and I just saw this. I really have no idea what "UDDS, HWFET and US06 driving cycles" are so I have no idea if this info will help, but if you check out the Android program called Torque and search this forum for custom pids that members here have developed, there is one in that set that returns some values for MG1 & MG2 torque. I've never used them so I have no idea what they report and if that would be helpful to you in what you are doing. Thought I would show my ignorance by mentioning this however
