Help lowering springs
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Gun owning Prius driver, Sep 11, 2012.
  1. Gun owning Prius driver
    397
    78
    Downey, California (Los Angeles Area)
    So buying springs this wednesday but i want to know which company gives the biggest drop. Pictures would be great. Thanks
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I believe its Tein then H&R then Eibachs then TRDs......from lowest 1st.
  3. smiff
    smiff New Member
    Beaumont, CA
    If I'm not mistaken, Tein's aren't available for Gen II...
    Eibach: front 1.4 / rear 1.0
    H&R: front 1.4 / rear 0.7
    Those are really your two best and easiest options.
    I've seen more praise for the H&R's...but if you want maximum drop, I guess try Eibach.
  4. Gun owning Prius driver
    397
    78
    I went to the installed and hd also gVe me tien as an option? It wasnt till after i left i forgot to get the part number to do some research. Also with their eibach kit they say it drops it 2 inches i think thats an approx but not sure.
  5. smiff
    smiff New Member
    Beaumont, CA
    Try to get a part number from him on the Teins and check online to see if he is giving you correct info. Also that 2" might be the "average drop" for Eibachs...not specifically for your Prius. I'm curious where did you go?
    **I'm also in the same boat looking to lower my Gen II. Probably going to go with H&R for a better ride and still decent drop. Would like to know what you choose and look forward to some pictures!
  6. Gun owning Prius driver
    397
    78
  7. Gun owning Prius driver
    397
    78
    I went to a place called salinas tires and wheels they have a bunch of locations throughout socal.
  8. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Depends what part of SoCal you looking in...
    I posted this a while back.. "Just got an update for SoCal B&G Spring installs. B&G located off Miramar Rd in SD: 9260 Trade Place, Suite 101, San Diego, CA: quoted me today $160 to install 'Their' springs. Unfortunately they couldn't sell me the springs under suggested retail price. $299. He didn't want to compete with the stores purchasing from him directly. B&G springs can be found HERE for $177.91"
    Member Justana said that if you call up a place called SD Tint 858.202.0200 you can get springs and install for $300. Just ask for 'Mike'.
    I can't decide to either go that route or this..Coilover sleeves from the Matrix and Vibe which member Toyotechwv has used.
    $275 Skunk2 - Spring Rate: Harsh - much stiffer ride.
    Part #:517-08-2450
    or
    ~$430 Ground Control - Spring Rate: Moderate - maintain closer to stock (saying this modestly) ride as possible.
    Part #:8070.01
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Not sure about the Tein's. I do know that when I had My gen2, Eibachs were discontinued so I was going go with H&Rs cause every shop I called said they no longer stocked Eibachs.
  10. smiff
    smiff New Member
    Beaumont, CA
    You can still find Eibachs either on eBay or random stockists even though they are discontinued. Did you end up with the H&R's then? If so, were you satisfied with them?
  11. Gun owning Prius driver
    397
    78
    Ill probably get the h&r i must have called 10 online stores and none had the eibach
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I traded in My 06 for a 2012 so I never got the H&R's installed. I just exchanged them for the gen3 H&R's & am very happy with them.
  13. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Sorry about the last one being so dark, this is my 08 on B&G Springs.
    [​IMG][​IMG]
  14. Gun owning Prius driver
    397
    78
    How much of a drop did you get off the B&g
  15. sdtundra
    1,314
    193
    Sacramento, CA
    Not sure on exact measurements but here is a before and after parked in the same position. [​IMG]
  16. lilryan
    lilryan Junior Member
    28
    Burlington, KS
    How is the ride compared to stock. I am after a little sportier ride, not just the look.
  17. macmaster05
    macmaster05 Senor Member
    4,050
    730
    B&G is 1.0" front and 1.0" rear, meaning you don't get a raked look. H&R is a little more reputable and well-recognized brand than B&G.
    I went through this decision 2 years ago and decided on H&R. I had to rule out Eibach because they didn't fit Touring struts. It's been the best upgrade I made and I have no issues so far.
  18. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    Good luck finding Eibach springs, last I've heard they weren't being made any more. I'm leaning more towards the H&R springs for my personal choice. I'll be looking at getting mine soon my shocks are wearing out... perfect time for some new springs!
  19. Gun owning Prius driver
    397
    78
    found some online, called them to confirm and they had some surus stock but also decided on h&r since they sre still made.
  20. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    The fact that Eibachs are no longer made for the gen2 raises some questions:
    What happened?
    Were there to many problems?
    It's not like there's no demand for them.
