Stubby AM/FM Antenna
Discussion in 'Gen 2 Prius Main Forum' started by flynz4, Jan 10, 2006.
  1. flynz4
    flynz4 Member
    332
    Portland, OR
    2015 Prius v wagon
    Is there a smaller antenna that fits into the standard base? If so, where can I get one? Thanks in advance.
    /Jim
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Probably cheapest on E-bay, Sigma Automotive sells a variety, probably any big name auto-parts shop should have a variety too.
  3. glenk
    glenk Member
    109
    Fairfield, CA
    There are a few sold on ebay for ~$15 including shipping. Just search for Prius + antenna and you'll see the variety of short antennas available. Anywhere from 4" stubbys to 7" or so. You'll definitely give up some AM reception with these though. Why do you want to change from the original? Car wash problems?
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    You can make your own from the stock one. All you need is a pair of side cutters and a dab of black paint.
  5. flynz4
    flynz4 Member
    332
    Portland, OR
    2015 Prius v wagon
    Once I get the satellite radio installed, I doubt that I will be using the commercial radio very often. I would still want it to work... but I would prefer to not have to remove it in a carwash... or if I put a Thule rack on top for biles and/or a box... then I would not want to have the interference.
    I assume when you remove it in a carwash... there is no risk of water getting inside through the socket?
    /Jim
