Temp. Guage(s)
Discussion in 'Gen 3 Prius Main Forum' started by john williams, Sep 16, 2012.
  1. john williams
    john williams Junior Member
    just bought a used 2010 prius. just noticed that there does not seem to be any temp. guage(s) for the engines. is this correct? if not, where do i get them to come on? no mention of them in the manual. thanx.
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    There is not one. If it does overheat you will get a regular ol' warning light though, but overheating is not common in Prius.
  3. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    There are quite a number of temperature readings available via the OBD2 diagnostic connection. Search for treads about ScanGauge and Torque.
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The car knows what temperature it is at but it won't tell you unless you buy an aftermarket device. As Rob said, search for Scangauge and Torque. Scanguage is a device that allows you to read four OBD-II outputs at once and you can easily switch between dozens of outputs by programming your selections. Torque is an Android App that requires you to buy a Bluetooth dongle that plugs into your OBD-II port and sends a signal to you bluetooth equipped Android phone, tablet or other device. The Torque App is far more versatile and less expensive if you already have an Android device.
  5. gliderman
    gliderman Active Member
    751
    225
    What Bluetooth devices work with Torque on a 2010 Prius?
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    You need a piece of hardware in addition to the Torque APP.
    You need to get the dongle that plugs into the OBD-II port, low priced ones are usually an ELM327 device, not sure about the higher priced ones. It transmits the OBD-II data stream using Bluetooth and AFAIK, most any Android 2.0 or higher device with Bluetooth will work with it. Maybe even older versions of Android?? The dongles run from about $25 to $100. Many people do fine with the $25 eBay devices.
  7. Tim Bender
    Tim Bender Member
    134
    44
    Spend the money on Torque especially if you already have an Android phone (maybe it works on iPhone now too, not sure). So many temperatures to track you'll have trouble figuring out which are important and which are not.
    Here's my current dash:
    Current dash by bendertj, on Flickr
    Here's an older display:
    Torque app prius by bendertj, on Flickr
  8. gliderman
    751
    225
    Can bluetooth be synced to more than one device at a time?
    Can I use torque on my phone and still have hands free phone?
    Thanks!
  9. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    Does the car have an oil temp sensor?
  10. RobH
    RobH Senior Member
    2,385
    991
    70
    There are two temperature sensors on the motor. I don't know how they relate to oil temperature.
    Other temperature sensors measure ambient air, engine intake air, engine coolant, catalyst (2), inverter temp (2), converter temp, inhaling air (HV battery), HV battery (3), and tires (TPMS equiped vehicles).
  11. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    Thanks, Rob. My 2009 Civic Hybrid was similar. It had sensors for the intake air, coolant, and catalyst, but not for oil.
  12. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Most cars don't normally have an oil temperature sensor unless the car came from the factory with an oil temperature gauge.
  13. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    Thanks, xs650. That makes sense.
