A Prius ECT Spoofer MCU Controlled
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ccdisce, Jan 11, 2011.
  1. Flying White Dutchman
    4,376
    313
    Got it to
    Nice instructions and nicely done
    -Htc Tapatalk ( sorry for auto spell correct )
    Meg&Bear likes this.
  2. Flying White Dutchman
    4,376
    313
    Almost done
    Using some of existing temp hack wires
  3. Flying White Dutchman
    4,376
    313
  4. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    FWD , what does the last pic show?
  5. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    It shows a Lillyput touch screen working with a Canview V4 from Norm at www.hybridinterfaces.ca. The screen shows the ICE temperature.
  6. ccdisce
    259
    187
    Stone Mtn GA USA
    Thanks for posting your install pics.
  7. ccdisce
    259
    187
    Stone Mtn GA USA
    IMHO the ECU seems to 'age-out' the earlier 'Idle-dance' after a preset time that we do not know.
  8. ccdisce
    259
    187
    Stone Mtn GA USA
    IMHO the ECU seems to 'age-out' the earlier 'Idle-dance' after a pre-set time that we do not know even tho the Prius is Ready, this it indicates by dropping out of S4 and initiating another idle-dance at the next stop
    If the ICE temperature is >185F it will attempt one but I think that it gets aborted to <10 seconds as I do not see the idle RPM getting tweaked above and around 960RPM.
    Making the Gen2 'not ready' seems to reset to S1 as soon as the ECU is shuts down, Thermos pump stops.
    If you slow to a stop and the ICE is OFF this is nirvana
    If you slow to a stop and the ICE ON here comes the Idle-Dance which may or may not be truncated.
    I am not sure if this aging process happens without the ECT Spoofer connected and the ICE temperature <185F.
    I will have to run some tests without it as I have been running my 2008 with an ECT Spoofer connected for the past 20 months.
    Meg&Bear and dave77 like this.
  9. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    Any chance one of these can still be purchased?
  10. ccdisce
    259
    187
    Stone Mtn GA USA
    Yes they are available for the Gen2 and Gen3.
    What model Prius are you planning to use it on?
    dave77 likes this.
  11. josh2008
    365
    144
    Princeton, WV
    Main one I was asking about was for an 05. With this work on my PiP as well?
  12. ccdisce
    259
    187
    Stone Mtn GA USA
    It will work with the 05 since that is a Gen2.
    I do not know what the PiP wiring looks like so I cannot say.
    I run a Prototype version on my 02 Mustang but it needs a part changed but I am very familiar with the wiring.
  13. josh2008
    365
    144
    Princeton, WV
    How much for one for the 05?
  14. ccdisce
    259
    187
    Stone Mtn GA USA
    $34 + $4 shipping and handling for the 05 kit.
    dave77 likes this.
  15. usnavystgc
    3,159
    990
    Tucson, AZ
    Worth every penny!!!!!!!
  16. Mister MMT
    Mister MMT Active Member
    285
    142
    Germany
    I got mine. It took a month to arrive, but went through customs without me having to pay anything.
    I'll install ASAP.
    Jan
  17. pjc
    pjc Member
    139
    46
    Bloomington, MN
    I have one of these spoofers and every once in awhile I get a P1116 code thrown. No warning icons or anything, the CEL just quietly comes on. This is the code for the "Coolant Temperature Sensor Circuit Stack for Coolant Heat Storage". Anyone else have this experience? I'm assuming it is from my ECT spoofer, since one of the potential causes of the code is (Note: CHS = thermos):
    A significant difference (over 25!C [45!F]) exists between the engine coolant temperature signal and the CHS tank outlet temperature sensor signal after a predetermined length of time has elapsed from the start of the coolant recovering.
    I just don't want to ignore a real problem with my actual temp sensor....
  18. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    I also have the spoofer and one morning got P1116 after several very short trips. It went away after a few regular trips. This may indeed be caused by the "perceived" condition you quoted above.
    Meg&Bear and pjc like this.
  19. TheForce
    3,461
    537
    Wheelersburg, Ohio
    P1116 is normal as long as you dont get it every time you start your car. I see it a hand full of times per year. Seems like it happens more in the winter time.
    [email protected] likes this.
  20. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    I've seen it too. It does tend to happen on an errand run involving several stops.
