Rough idle in a morning.
Discussion in 'Prius c Technical Discussion' started by Toothpicker, Oct 1, 2012.
  1. Toothpicker
    Toothpicker Junior Member
    31
    CT
    Mornings are cooler now in connecticut. I mention that at cold start my Prius C idles pretty rough.
    Does anyone else has the same issue?
    BTW, I just did my 10K miles service today. And it is second oil change I made.
  2. RocMills
    RocMills Active Member
    789
    277
    Las Vegas, Nevada
    The only time I experience what I would call a rough idle is when it chill *and* I have let the battery get too low. Your temperatures are probably much lower than mine, so that could be the cause.
  3. managerman
    managerman Prius v Nerd
    228
    110
    Columbus, OH
    The only time I have experienced rough idle in the morning is if I have moved the car from the driveway to the garage the night before and did not let the initial warm up cycle complete..I have verified this a few times...now I just put it in EV mode when moving around the driveway.
    Hope that helps..
    -M
  4. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    I get it on my 2012 Prius III.
