Running out of Gas
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mwbprius, Jul 5, 2012.
  1. mwbprius
    mwbprius Junior Member
    22
    Connecticut
    I did a little experiment. Driving home from a long trip my out of gas indicator started blinking. My range said I had about 8 miles left to my house. Knowing it was only about 3 miles I decided to just go home and charge over-night and then go to the gas station. About 1/2 way home my range was down to zero, there are hills I have to go up, so the range calculation is off. It was a bit scary driving with the gas gauge blinking and my range a zero but I made it home. The next day I drove to the gas station on EV and the car only took 8.6 gallons.
    Moral of the story--in my case at least--there is about 2 gallons left when the car tells you you are out of gas and you have zero range.
    lensovet likes this.
  2. Calvin Perry
    Calvin Perry Junior Member
    Mineral, Va
    I had the same experience. When I pulled into the gas station for my first fill up it was flashing and said 7 miles remaining. It also only took 8.6 gallons.
    Calvin
  3. bisco
    51,846
    i think they want you to find a gas station while you still have the safety amount of gas left and not after.:)
  4. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    Its also not clear you can get to ALL of the gasoline in the tank, it depends in where the pickup is, and you rely don't want to be running it out, it could be costly to replace the gas filter, and who knows what else. Please don't run your Prius out of gas.
    goddess prii likes this.
  5. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    Also, the fuel pump in the gas tank needs gas for cooling so it doesn't burn up pumping when there is no gas to pump and to keep the pump cool. I always don't let my car get below 1/4 tank after burning up a fuel pump in a Chevy I once owned. It is really a lot of work to replace the pump when you have to drop the gas tank to replace it.
  6. Dark_Prius
    Dark_Prius Member
    146
    LA
    I should have read this post before I head out this morning with my 150mile trip.
    I left my house with 2 bars, full charged. The last gas bar started to blink, I figured I got full charged and 2 gas bars left in the tank, I can at least go 100 miles plus my EV as back up. Lets test the limit.
    I hit 110 miles after the light blinking, at that time, I still have 7 miles EV range.
    All sudden, my gas puddle stops working, I cannot accelerate at all even with 7 miles EV range, it was scary since I was still on the freeway.
    Lucky, there wasnt any jackass who won't let me pull to the slow lane. I glided off the ramp and all sudden, the car operates normal again. So I made it to the gas station with EV and still had 5 miles EV, and took 10.48 gallons to fill up.
    Hope my gas pump is ok.
    LT26i ? 2
    Redpoint5 and lensovet like this.
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    isn't gas like $5.50 a gallon in LA?
  8. CharlesH
    2,796
    1,163
    Roseville, CA
    It's getting close to that in the SF Bay area. The excuse this time is refinery problems resulting in a shortage of the special CA blend.
    Thinking like an oil company executive: There are two choices:
    A) Spend a lot of money to modernize and expand the refineries in California, which will result in adequate supplies and modest retail prices and lower profits.
    B) Spend nothing and let the decrepit refineries break down/explode (happened recently)/whatever, causing shortages. Retail prices and profits skyrocket.
    I wonder which they will chose? :rolleyes:
  9. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Not quite, but headed there. Two hours ago the most I saw was $4.79 for regular, but stations are changing prices more than once a day. The lowest price at that time was $4.49.
  10. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Your very lucky. I wouldn't push it to Empty, as you did.
  11. lensovet
    2,615
    496
    Burlington, NJ
    this is actually great info.
    don't ask why, but i have had plenty "near-death" experiences with low gas levels in my cars over the years. my experience has shown that on both Hondas and Toyotas, the low fuel light generally starts blinking with about 2 gallons left. Dark_Prius's experience seems to confirm this, because he got 110 miles – at 55 mpg, that's two gallons right there.
    The "confusing" thing about the Prius gauge is that in most cars with analog gauges, the needle first drops to zero, and then the light goes off. in the Prius, the last bar and the light are the same thing, so that might catch you off-guard.
    But the really nice thing from this experience is that if your speed is low enough (below 62), the car WILL drive with no gas if you have EV range. The non-plug Prius would just shut down completely when it ran out of gas, regardless of the SOC of the battery (mom had an experience like this once).
  12. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I was filling my car once when a VW Beetle pulled up to the pump, sputtered, and died. It had run out of gas right at the pump!
  13. terpsmandan
    terpsmandan Member
    144
    When the light goes on my PIP takes 8.25 gallons.
  14. Rebound
    3,996
    2,644
    Portland, OR
    The most gas I've put into my PiP is 8.5 gallons.
  15. rwyckoff
    rwyckoff Phev's Plus Home Solar power1
    82
    Green Valley AZ.
    Literally hundreds of people have reported running out of gas in thier Prius's (all generations) over the last 9 years and no one has subsequently reported having to replace thier Fuel pump. Same thing with over filling the gas tank and having to replace the Carbon air filter, nor has anyone ruined their hybrid battery by running on it after running out of gas. This is the value of keeping tabs on a Chat group over time. Use it!
  16. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    I had my last flashing light on last night. Have to drive to work today (30 miles each way and charge at both ends). Gas is like 4.80 a gallon, so I put in 2 gallons. That will last me a couple of weeks until winter blend is fully released and prices come down. Man I love this car!
    Rebound likes this.
  17. terpsmandan
    terpsmandan Member
    144
    Me too. 150 mile round trip. Full charge once per day (overnight) and 55-59 mpg.
  18. Rebound
    3,996
    2,644
    Portland, OR
    WRONG.
    Many people have reported that running out of gas caused their Prius computer to lock up, requiring that the car be towed to a dealership, costing hundreds of dollars.
    Second, damaging your fuel pump and/or charcoal canister isn't a good idea.
  19. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    I ran out of gas no less than 4 times in my Gen II. Each time all I needed was some gas to get to the gas station and I was fine. 2 of those times I had enough oomph left in the battery to get to the gas station. No computer lockups, no fuel pump replacements, no battery draining. The car was very good at protecting the traction battery. When the SOC got below a certain point, it just drove slower and slower, giving me enough time/distance to pull over safely. It made sure to keep enough charge so that it could fire up the engine when there was enough gas in the car again.
    While running out of gas is never a good idea in any car, it's not the end of the world if you do so.
  20. devprius
    devprius /dev/geek
    979
    291
    BTW, that Gen II now has some 170K miles on it and is still running fine.
