Dumb(?) Question
Discussion in 'Gen 3 Prius Fuel Economy' started by CaliforniaBear, Oct 14, 2012.
  1. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    MFD = mileage from display?
    FCD = fuel consumption display?
    These are the same and are the reading on the display from the trip mpg that you reset when you fill the tank. Correct?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    MFD typically stands for Multi-Function Display and refers to the Instrument Panel on the Gen III's.
    Not sure about FCD.
  3. CaliforniaBear
    1,180
    289
    Northern California
  4. jdcollins5
    5,131
    1,346
    Wilmington, NC
    OK. F8L is using FCD for Fuel Consumption Display .
  5. CaliforniaBear
    1,180
    289
    Northern California
    How about an acronym list for newbies....
  6. ursle
    ursle Gas miser
    1,049
    192
    NH
    mfd
    ice
    thank god danny had a good idea
  7. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
  8. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I thought MFD (Multi Function Display) is for the Gen II (2004-09), MID (Multi Information Display) is for the Gen III(2010-~). The nav screen in the Gen III is now, just a nav screen lol. Yeah, 2012s can do more than the 2010/11 on the nav screen but with the MID on top I'd still just refer to the nav screen as the nav screen.
  9. jdcollins5
    5,131
    1,346
    Wilmington, NC
    You are right. The Gen II is the MFD and the Gen III is the MID.
  10. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    There is a link to the Prius glossary in the Gen III main forum.
  11. CaliforniaBear
    1,180
    289
    Northern California
    Thanks! I really needed that.
    Then there is the definition of "Consumption". Per the dictionary "The using up of a resource". I would expect that to be how much gas was used but, of course, that isn't very interesting in this application. So, for Prius, it means miles per gallon. So it is actually "rate of consumption" where the dimension for rate is distance.
  12. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Yep to all of the above.
  13. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    For the rest of the world, fuel economy is expressed L/100km. The word "consumption" is correct there. I suspect they just carried over the translation. A better word would probably be ECON for economy.
  14. CaliforniaBear
    1,180
    289
    Northern California
    I don't think the UK definition of Consumption means "rate of use" it just means "use". See consumption - definition of consumption by Macmillan Dictionary
    The translation problem may have been from Japanese :)
  15. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
    I can understand the CONS for L/100km, but ECON doesn't tell you squat! How about MPGs? After all that's what it is, good, bad or indifferent.
  16. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Except that most of the world drives kilometers and buys by the liter or litre although some consume Imperial gallons (and pints).
    David, BTW, the only dumb question is the one not asked.
