Anyone knows the size of this bulb
Discussion in 'Gen 3 Prius Main Forum' started by Rainking, Oct 16, 2012.
  1. Rainking
    Rainking Member
    164
    New York
    I have a 2012 PiP, but I think it's the same for all 2012 Prius. What size is this bulb? I want to replace it with an LED. I'm trying to replace as much bulbs as I can to LED. Thanks!
  2. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
  3. Rainking
    Rainking Member
    164
    New York
  4. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Mine came with LEDs.:D
    sprtent and Rainking like this.
  5. sprtent
    sprtent Member
    104
    75
    SF Bay Area
    Here's mine using Ebay cheap led 194/168 6K bulbs. I recommend using bulbs with leds on the sides and also on top. Nice little upgrade :)
    Rainking and Jonny Zero like this.
  6. Rainking
    Rainking Member
    164
    New York
    Nice! You got a link? :D
  7. sprtent
    sprtent Member
    104
    75
    SF Bay Area
    Rainking likes this.
  8. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Don't forget to change the ones behind the amber side reflectors too. You will have to loosen the front bumper and remove the headlights to get at them though.
  9. Rainking
    Rainking Member
    164
    New York
    Cool. Thanks. I got these since they were cheaper and looked the same. Might get another set since they fit so many other lights.
    4X T10 W5W 194 168 501 Car White 20 SMD LED Inverted Side Wedge Light Bulb 12V | eBay
    Okay, will do. Thanks!
  10. xliderider
    8,140
    3,277
    Honolulu, HI
  11. Rainking
    Rainking Member
    164
    New York
  12. xliderider
    8,140
    3,277
    Honolulu, HI
    Direct quote from the item listing:
    IIt is designed mainly for Fog Light lamp, Daytime Running / Driving Light DRL lamp use.
    In other words, they are not meant to replace the low beam bulbs on your vehicle. They simply aren't bright enough. I purchased cree projector LEDs for my foglights, and they are no where as bright as the 55w halogen bulbs they replaced. I'm OK with it though, as I'm only using them as DRLs.
  13. Rainking
    Rainking Member
    164
    New York
    Thanks for the info. I guess the only option would be OEM led headlights?
  14. xliderider
    8,140
    3,277
    Honolulu, HI
    No, another option is to buy an HID conversion kit. There are several threads regarding those, what brand, how much, color temperature, wattage, etc.
  15. Rainking
    Rainking Member
    164
    New York
    I'll post the lights that I've updated to LED. My goal is to replace everything to LED that I can.
    License Plate
    Parking Light
    Jonny Zero likes this.
  16. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
