Quietest snow tire?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ProximalSuns, Oct 9, 2012.
  1. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Weirdly formatted dupe.
  2. ProximalSuns
    1,877
    PNW
    Is it worth putting steel wheels on your winter tires? - The Globe and Mail
    No benefits really. He is going to drive on ugly wheels to "save" his good wheels which makes buying the nice wheels in the first place a dumb idea since you are driving ugly half the year.
    He says mounting tire is "stressful" on the tire. No evidence of that and at once a year it never really amounts to "stress". Covered by every tire warranty.
    So if you want to drive around on ugly wheels 6 months of the year, not knowing if you are getting a flat in the worst driving conditions of the year to be stuck in a car with no spare while spending more money for the 2nd set of ugly wheels...go to it.
  3. Vas25tl
    Vas25tl Member
    268
    77
    Milwaukee
    How did we drive all those years before TPMS sensors?
  4. ProximalSuns
    1,877
    PNW
    Same way we drove without traction control, stability control, ABS brakes, DRL's, air bags, seat belts and tubeless tires...much less safely.
  5. Vas25tl
    Vas25tl Member
    268
    77
    Milwaukee
    I'm not sure I'd have TPMS sensors in the same category as traction/stability controls/abs/air bags. If your tire blows out at 70mph, the sensor isn't going to help you steer to the side of the road.
  6. Vas25tl
    Vas25tl Member
    268
    77
    Milwaukee
  7. Vas25tl
    Vas25tl Member
    268
    77
    Milwaukee
  8. Vas25tl
    Vas25tl Member
    268
    77
    Milwaukee
  9. ProximalSuns
    1,877
    PNW
    But if it warns you that a tire is losing pressure you can get to the side of the road before it "blows out at 70"...ounce of prevention, ton of cure issue.
    And with a car with no spare tire, getting an early warning and getting to a tire shop is even more important especially in harsh winter months on windy mountain pass roads to ski resorts.
    TPMS can save your life.
  10. Mendel Leisk
    40,469
    No, it's your call, though I guess I am trying to make a convert, LOL. There probably are wheel covers, to pretty them up, but then you're into cheap aluminum rim territory, dollar wise.
    But I don't understand the "no spare" you mention. Maybe you're muddled? I've got a regular 3rd gen Prius, albeit with the 17" OEM tires. 15" snows work fine though.
  11. ProximalSuns
    1,877
    PNW
    The "temporary" is not really a spare especially in winter driving conditions. Having the TPMS, making it to tire repair spot can be life saver in winter driving conditions.
  12. Mendel Leisk
    40,469
    It's 4 degrees centigrade and raining..., I think today's the day. Any time ambient temps fall below 7 deg the snows have an advantage, due to staying more pliable. One advantage to black steel rims (anyone remember silver steel rims?), they really say snow tire:
    Centre caps would help.
  13. enigma88
    enigma88 Junior Member
    34
    Alberta, Canada
    I got the Michelin X-Ice 3s yesterday and they were quite quiet on the drive home. Of course, it was only a short trip so I will have to wait until work on Monday for a better idea of how quiet the tires are.
    I have this stud/rod sticking out of the front tires (as shown below). I got it installed at Costco, did they forget to remove the studs or is it suppose to be like that?
    Also, there is some rust on the inside of my allow wheels. Is this normal? Can/should I do something about it?
    Thank you for your time.
  14. Mendel Leisk
    40,469
    The oem aluminum rims are corrosion prone at the points of contact, especially around the centre hub, they'll almost glue on. In my experience at least it's not the solid locked-on corrosion: a little bit of kicking pushing and they'll come loose. I wire brush it off, both on the brake caliper hub and the back of the wheel. A smallish copper bristle (steel will do, but copper is more gentle) brush is good for this. I also use the brush on the stud threads, clear them a bit.
    Then, before putting wheels on, I put a sparing amount of anti-seize compound on all the contact points. You want it complete but very thin: centrifugual force will cause it to migrate outwards, even when applied sparingly.
    The "stud/rod" is unfortunately the main front hub bolt. If it didn't protrude out the kind of centre caps that come with 17" rims would cover that. They're a perfect fit on the Corolla steel rims, but that hub bolt sticks out to far, will pop them off.
    (I just came in from putting ours on ;))
  15. ProximalSuns
    1,877
    PNW
    In high snow, high salt conditions like SLC, it seems that is more of theoretical problem than a real one. No big issues with corroding alloy wheels in SLC. Likely frequent car washes make that a non-issue.
  16. Vas25tl
    Vas25tl Member
    268
    77
    Milwaukee
    To me TPMS sensors are about convenience, not a life saving improvement.
    Any pics of the entire car?
    I just got an email, I can get the black 17" scion TC wheels with Blizzaks for $500. Comes with TPMS, which I would have to reprogram. Strongly considering it....
  17. ProximalSuns
    1,877
    PNW
    To US Dept. of Transportation and Insurance Institute TPMS are a mandatory life saving improvement. In this context of winter driving, with cars having no real spare, winter conditions, getting stranded with care immobilized...can get dicey.
  18. ProximalSuns
    1,877
    PNW
    Had to laugh...I took off the plastic hubcaps from my all black alloy wheels.
  19. Mendel Leisk
    40,469
    Almost the whole car, and yes, they do look funky ;)
    The (15") steel rims were $70 per, actually Corolla.
  20. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    This weekend I asked my bro in-law (he's owned/operated a auto repair shop for 35+ years) if I should get dedicated rims for my snows or just have him mount them on the OEM rims- he said without question get rims for the snows. He mentioned wear and tear on the OEM rims and the tires as the main reason for getting dedicated rims for the snows.
    As to the TPMS sensors- I'll do without for 3 months- none of my other cars have them and it hasn't caused a problem yet.
