Anybody modified the seat heater switch to Hi-Lo-Off?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by krausternet, Oct 21, 2012.
  1. krausternet
    krausternet Member
    137
    24
    SF Bay Area
    It's a little ridiculous for me to be asking this considering that 1) I don't yet own a Prius. 2) I've never had heated seats and don't know much about them. But my wife came back from a trip with a friend and said the next car should have heated seats. Having asked here on Priuschat about heated seats I've learned that the switch for them is an On/Off switch and that the seat is very quick to heat up and that the seat gets very hot. A few questions come to mind:
    - is it possible that next year's model, coming in weeks, will have an two level or switch? Do other Toyota models have two level switches that might make this type of change easy for the Prius line to do? (Answer to first question is probably: nobody knows, wait and see.)
    - has anyone modified the heater switch to make it a Hi/Low/Off or maybe a variable thermostat?
  2. Adam Leibovitch
    498
    102
    I believe this has been fixed in the newer models.
  3. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    My 2012 Prius Five (mfg date of 01/12) had just on/off for the seat heater.
    My 2012 PIP (mfg date of 06/12) has Hi/Off/Low switch for the seat heater.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    My 2012 PIP (mfg date of 5/2012) has Hi/Off/Low heated seats.
  5. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    So . . . Is there a mod for the Gen III? It sounds like there should be something available.
  6. bisco
    51,567
    maybe you can by pip switches and relace originals.
  7. Texas-Prius
    Texas-Prius One more Prius to fight terrorism
    79
    32
    Austin, TX
    It might be worth it for those of us that do not have PiPs for someone that has a PiP to pop the switch out and run an Ohm meter on it. If the switch is the same size, and it just has a simple resister built in to it; it might be as simple as ordering the PiP's switches to replace the ones we have. Any PiP owner want to take this on?
    - TP
  8. ny_rob
    1,968
    813
    L.I.- NY
    Sorry- I finally have a rattle free Prius (the Five had many frustrating rattles/buzzes/squeaks, etc..) and I'm not touching jack on this car till I have to. I was even hesitant to inflate the tires to 40/40 this weekend- but it's still rattle free thank goodness.
    Maybe post your request in the PIP forum for a taker...
    ursle likes this.
  9. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Unless you drive your car naked I personally don't find the seat heater in my V to be too hot. I'm guessing its the same as in the 2012 liftback. If anything I wish it was a tad warmer. Winter is officially here in this part of the world and anything below -5 I leave the seat heater on all the time. I notice it will get really warm when you first turn it on, then it cools off for a few minutes, then heats up again for a few seconds, then repeats the on off cycle. Must operate on a thermostat. I hope when it actually gets cold out it will stay on longer.
  10. N2Wind
    N2Wind Junior Member
    Morganton, NC
    My 2012 Prius package 4 has lo/high.
  11. Texas-Prius
    79
    32
    Austin, TX
    Interesting. I have a 2012 Four, and the switch only has one setting. Maybe you got an additional package that I didn't get?
    - TP
  12. N2Wind
    Morganton, NC
    I bought mine in June 2012, so it may be a later manufacture. My wife's 2011 Ford Edge that we bought in 2011 has a few different things than the same model that we bought in 2010 (due to a wreck.)
  13. Texas-Prius
    79
    32
    Austin, TX
    I bought mine in August 2012 with a manufacturing date of June 2012.
    - TP
  14. DaWeav
    DaWeav Junior Member
    91
    Lemoore, CA
    Well, I just checked out a 2013 package four and the switch can only be depressed. No hi or low setting from what I could tell.
    GT-P7310 ?
  15. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    On/Off for the factory heated seats seems to work fine for us. My guideline is, "if it aren't broke, don't fix it."
  16. Danger
    Danger Member
    175
    22
    Frisco
    I don't mind the on/off switch. I just hate the placement. Anyone ever try to relocate the switch to a more ergo place?
