I RESET my Trip B again. DAMN.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ukr2, Oct 22, 2012.
  1. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    Toyota Engineers,
    PLEASE make it harder to Reset Trip B and EV 2.
    I use them for my Gas Fillup data.
    Today I went to Reset Trip A, but Trip B was displaying and it Reset instead. DAMN.
    Since March when I got the PIP, I've mistakenly Reset Trip B 3 Times.
    DAMN. DAMN. DAMN.
  2. Mendel Leisk
    40,251
    The one thing that is bullet-proof is the odometer reading. Where you are now, you might be able to calculate the number by looking at the trip records, it holds the last 4 or 5 on one of the screens (if sim. to reg prius).
  3. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    I haven't seen these past Trip Records with the PIP. How do you get to them?
  4. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    One thing that helped me was noting that the 'B' in trip B was reverse video (i.e. dark B, light background). That made it easier to notice which was displayed.
  5. bisco
    50,825
    we need an 'are you sure you want to delete trip B?' warning.:D
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    IS THAT YOUR FINAL ANSWER??
    DadofHedgehog likes this.
  7. bisco
    50,825
    exactly.
  8. yukit
    yukit Junior Member
    SF Bay Area, CA
    I keep the between fillup mileage with Trip-B as well.
    How about making Trip-A auto reset after each trip (car shutoff for a least 30 mins) my old car did that.
    So I would be resetting the Trip-A manually less often to avoid accidental reset on Trip-B.
  9. Mendel Leisk
    40,251
    With 3rd gen Prius, here's an excerpt from page 36 of Owners Manual:
    And hopefully this reflects your manual (cut-and-paste from a pdf I downloaded):
    I think you just give repeated short pushes of the trip meter, to cycle through all the trip displays, and this record of past trips is one of them, showing the miles along the bottom.
    I've used this once or twice when the trip meter was inadvertantly reset without being recorded. After a while though, I decided just recording the odometer readings was much safer.
  10. fuzzy1
    10,332
    If you don't unintentionally reset the Trip meters, a service tech may do it for you. That happened only once to me, but then I have to do it too as least once a year. A paper record is the real keeper of my long term data.
  11. bisco
    50,825
    pip has monthly fuel cons screen, but i don't think past record screen?
  12. Mendel Leisk
    40,251
    ^Ah, you're right.
  13. bisco
    50,825
    too bad, that looks like a good one. you would think with software, it would be cheap and easy to add as many as possible. maybe select the ones you want to scroll through.
  14. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    I haven't screwed up yet, but I'm sure it will happen. In the meanwhile, I use 'a' for per tank miles, and 'b' for lifetime. I have to keep a detailed mileage log for business use, so I write down the actual odometer readings for that purpose. On my Gen ll's I found service techs and the occasional parking valet would manage to reset things, so I got in the habit of turning off the display. Don't know if that will work on the PiP.
  15. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    My Trips have black A and B.
  16. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    Roger,
    It's too easy to reset the trips or have them reset by a tech or another driver. Having one for Lifetime info Will be a losing effort.
  17. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    So because I Reset B, I decided to Fillup early and start over with a new tankful.
  18. Mendel Leisk
    40,251
    Not if you use the odometer.
  19. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    What do you mean ML?
    The OD is just Lifetime Miles of the car.
    The Trips have Miles since reset, Cons.MPG and avg MPH.
  20. bisco
    50,825
    wouldn't it be nice if the odo tracked average consumption and mph?it's probably in the computer somewhere.
    ukr2 likes this.
