My horn just became female...
Discussion in 'Gen 3 Prius Technical Discussion' started by Irvin Zamora, Oct 30, 2012.
  1. Irvin Zamora
    Irvin Zamora Junior Member
    Desert Hot Springs, California
    Ok lol, all joking aside...
    just a few days ago I had to honk my horn, and it sounded pretty normal..and all of a sudden, 2 days later I was honking outside my girlfriends house and no joke, it sounds like a toy car going boop boop! -_-; I was honestly embarrassed by it, now my girl wont let me down on it unless I fix it LOL...
    So I have no idea what went wrong? Is it possible for a horn to malfunction?
  2. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    Horns can fail just like anything else. It's possible to add a more "assertive" horn. You use a standard automotive relay, wiring the existing horn wire to the relay coil. Then the relay runs battery power to the new horn. I used two "truck" horns in my 4X4 - they are usually made in pairs such that the frequency of the pair beats in a painful manner. You can then put in a two position switch such that position one uses the stock horn (excuse me please), and position two uses the new horn (get the *&%$# out of the way!!!). ;)
  3. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    There are two horn speakers, high tone and low tone. They are supposed to work at the same time to produce a normal tone.
    If your car sounds like a Fisher Price special all of the sudden, your high tone speaker might have gone out. Take a quick look under the hood to see if the connector worked its way loose. To early for it the fail complely.
  4. Irvin Zamora
    I went ahead and made sure the connectors were attached correctly, one of them was slightly lose, but didn't seem to be the problem... still getting the BOOP BOOP >.< Is this something I can take to the dealership to have it looked at?
  5. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Your 2012 car is still under warranty right? I would take it in and have them look at it.
  6. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I would rather have them Listen to it, you can look at it all day, it ain't gonna fix itself! :D
    dustoff003 likes this.
  7. WE0H
    WE0H Senior Member
    3,247
    528
    Stuff a set of train horns in there.
    Mike
  8. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    It probably swallowed a bug.
  9. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    I just took out a 4 inch long grasshopper stuck under the bracket for the outside temp sensor, inside of the low grille. I could not reach in there. In the end, I used a pair of disposable chop sticks from Chinese takeouts to loosen it, and then to take it out through the grille opening.
