Newbie? Gen2- where is the liftgate release??
Discussion in 'Newbie Forum' started by SteveWlf, Oct 30, 2012.
  1. SteveWlf
    SteveWlf Old-on-Hold
    262
    33
    Montesano, WA
    Probably sounds like a dumb question to those who know the answer! I'm a new Gen1 owner and now looking for a Gen2 at auctions, etc.. More often than not, the key fob is not available when I go to inspect these prospects. Doors are unlocked but never the lift gate/hatch. In a regular car I would expect that a manual release would be near the drivers door/seat area. Nah! just the gas door release. The owners manuals are seldom available. I'm also accustom to having an emergency release where I can open the hatch from the inside. Often a trip, near the inside of the latch. Nah!
    Just how do you open the hatch on a Gen2 when there is no electrical power or don't have the Fob?? (Keyless Entry??)
    Thanks
    Steve
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    Feel around directly under the Toyota emblem on the hatch. There is a rubberized "button" there. Press up on it like you are trying to lift the hatch and it will click and release. It is in the same place on the GenIII.
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    Ohh and FYI, do NOT press down on the spoiler to shut the hatch. Press on the Toyota emblem, the license plate or use the handle on the inside. You'll break the spoiler if you press on it too hard!
  4. SteveWlf
    262
    33
    Montesano, WA
    Thanks for the replies and cautions.
    Is that button machanical or electrical?? Most of the time, I have found that the batteries are dead on these cars.
    Steve
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    Electric. If the battery is dead then you would have issues getting in there. :( I think anyway.
  6. wjtracy
    wjtracy Senior Member
    11,365
    3,608
    Northern VA (NoVA)
    If I recall there are past threads on how to modify for mechanical entry but does not seem practical for this case
  7. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    You have to crawl into the back area from the inside. There is a plastic panel that you have to remove on the hatch to expose the hatch release. If you can find a gen II manual it will show the exact location. I did this once a few years ago on a 07. Good luck.
  8. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    That plastic panel is dead center on the rear edge of the deck in line with the latch. Is the auctioneer really going to let you crawl inside a car & remove a plastic panel so you can trip the hatch release?
  9. SteveWlf
    262
    33
    Montesano, WA
    Hmmmm! A 'heck' a situation when you need to check or jump a dead battery or to do a quick disconnect of the main HV battery system.
    I suppose all of this is to keep the Valet from snopping around in the luggage;)
  10. SteveWlf
    262
    33
    Montesano, WA
    Speaking of Jump Starting: Isn't there a pair of terminals under the hood for jump starting, (kinda like the late model Saturns that have the battery in the trunk)??
    The main reason I want to get the yard battery in the terminals, is not to start it but to read the codes with my OBDII scanner. (I could be wrong, but I think the "Prius aware codes" are held in memory, even if the Aux battery is dead. That was my experience with my Gen1).
    Steve
  11. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Yes there is a positive jump start terminal under the hood. (any large chunk of metal is a negative terminal)
