Garage charging stations
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bzyrice, Oct 31, 2012.
  1. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    Now that I have a PIP I want to see what others have done as far as their charging stations in their garage. Let's see some pics so I can get some ideas!
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Do you really want to spend the money for it? If I had a PiP, I wouldn't bother. ~3 hours isn't that long to wait for a full charge.
    Zythryn and bzyrice like this.
  3. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Congrats on the PiP.. I followed your build thread from before.. cant wait to see what you have in store for the PiP.
    I bought Mitch's OpenEVSE (EVSE_by_mwolrich - open-evse - A portable EVSE built with an Open EVSE board. - Open Electric Vehicle Supply Equipment (EVSE) - Google Project Hosting ). Those are his pictures.. but its now hanging on my garage wall. I need to figure out a few things still since I dont park my car in the garage but the EVSE is in the garage..
    bzyrice likes this.
  4. bzyrice
    805
    324
    West Palm
    I just meant, I want to see how others plug in there cars in the garage.. Did u guys make anything special? Or just a plug in the wall?
  5. bzyrice
    805
    324
    West Palm
    Thanks! I live making build threads!!
    Ooh how much was that charging station?
  6. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    It's not even a full 3hrs to charge- it's really closer to 2.5hrs for a full recharge on 120vac...
  7. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    Here in Northern California, I keep my car in the driveway. With the PiP, I've become good at backing into the driveway to charge.
    I installed a dedicated, weatherproof outlet myself, as you can see below. I installed some simple hooks into the stucco, which look fine. It's been very easy to use, taking only about 15 seconds to plug in when I get home at night.
  8. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    If you only need to charge at night (for your morning commute) and in the afternoon (for your commute home), then I'd say 120V is fine.
    But getting 1 hour's worth of juice after you get home is a pretty big difference between 120V and 240V.. its like 4 miles of range versus 8 miles. I can make it to the friends house/store/shopping center and back with 8 miles, but not with 4 miles. Additionally, since I kind of live on a hill, that trip home uphill from the store on gas is painful.. that's probably the main reason why my HV MPG is the worst out of everyone on the spreadsheet.
    It really depends on how you use your car.
    DadofHedgehog likes this.
  9. elife
    elife Junior Member
    37
    Northern Virginia
    Here are a couple photo's of my charging setup. Very simple but very efficient. Takes about 30 seconds to plug in or disconnect and the charge cable. Rolls neatly on hook (already in garage). I did have a 20 amp dedicated charging circuit put in. It cost me about $350 and that included one other job that the electrician did while he was here. For the first couple of weeks I just used one of the garage outlets with no issues. However I do have a battery powered lawn mower that I charge after each use as well as other things so decided to get a dedicated circuit. Also, the garage door opener used the non dedicated circuit. The charge time from the outlet is about 2 hours and 20 min. I have timed multiple times - must have good current flow. I use velcro to hold the CCID (black box on charging cable) to the table so it does not pull off. My wife pulls her 2000 Honda Accord beside my car with no issues. I think it will save you time in the long run to think out an efficient way to set yours up. Makes life easier!!
    lensovet likes this.
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    still haven't painted the wall yet I see, lol
    elife likes this.
  11. lensovet
    2,615
    496
    Burlington, NJ
    nice setup! i like the velcro idea too. i really wish they had made that box much smaller and lighter, is it is, it needs some sort of "shelf" because you can't just leave it hanging – very annoying.
  12. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
  13. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
  14. bzyrice
    805
    324
    West Palm
    So everyone's setup is pretty much the same. Just a hook and wrap it around the hook. This looks like the route I will go with fro awhile.
    Tracksyde - I may get a dedicated circuit later, but for now a regular wall outlet works for me..
    So, do all of you guys leave your charging cord at home? Buy another cord that stays with the car?
  15. Adam Leibovitch
    498
    102
    My charging cord stays in the car.
    I have some different 240v outlets around my house. Does that open any low/no cost faster charging options? I have a dryer plug where an electric dryer used to be, and one of those round twist lock outlets in the den. Could I just stick an adapter on and get a faster charge with the OEM evse for example?
  16. mitch672
    1,077
    198
    Randolph, MA
    NO, not without modification, you will destroy the EVSE unless its modified to handle 120-240
    Checkout EVSE Upgrade - Products $239.00 + $20 return shipping EVSE Upgrade - Order
    This has some specifics mentioned about the Toyota EVSE: EVSE Upgrade - Products
  17. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Mitch, I was actually looking at that today. Your new one looks crazy :D.. It will match your Model S well.
    I finally got my outlet on Monday. So Tuesday morning was my first charge using your EVSE. Everything worked great, thanks again for all your advice.
    Also, something others may find interesting regarding charge time. The first night I charged on 240V, I set the timer to end at 830AM. When I went to check on it at 715AM, it was already done. However, today (day 2 on 240V), with the timer set to finish at 830AM again, I went to check on it at 8:00AM and it was still charging. When I went back to check at 8:10AM, it was finished already.
    So maybe the charge timer kind of adjusts? Or maybe switching between 120V and 240V, the charge timer needs to take a charge or two to "figure things out".
  18. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
  19. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    The EVSE brick has a li'l hole in a corner, perfect for a long zip-tie or for a piece of string or wire to make a permanent loop, so that the user can hang the brick off of whatever is handy next to the outlet.
  20. DadofHedgehog
    681
    282
    northern Virginia
    Try the Evse Upgrade (on Google and in many older posts here). It'll give you automatic 120 - 240 charging.
