Oil leak via timing chain cover
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by vnhk, Jan 6, 2011.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    How many miles on it?
  2. CivicQc
    CivicQc The world needs more prius
    233
    99
    Planet Carbon
    57 000 km
    35 400 miles
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Heard of freon dye for leaking ac but not for leaking oil. Please elaborate.
  4. The Critic
    3,193
    2,330
    CA
    There are leak detection dyes for engine oil as well.
    iPhone ?
  5. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Did not know that. Thanks.
  6. El Dobro
    El Dobro A Member
    7,079
    3,259
    There is a dye for coolant leaks, too.
  7. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Knew that as my prev post stated.
  8. El Dobro
    El Dobro A Member
    7,079
    3,259
    Your previous post says freon, I'm talking about antifreeze/coolant.
  9. hollyg
    hollyg New Member
    Franklin TN
    Just came back from the dealer with a routine oil change.I was told my 2010 Prius had a timing cover leak. I was told it would cost $2600. I told them I could not afford to fix it at this time , since he told me it was minor and I could wait a bit to get it fixed. Then the manager came out and told me he would give me a deal for $2500 to fix. No pressure he said. I declined. As I was walking out, I got a quote for $1490.61 good for 30 days. What should it cost to fix a leaking timing cover?
  10. xliderider
    xliderider Senior Member
    8,134
    3,273
    Honolulu, HI
    @hollyg, this is an older thread, but I had a similar problem. Here is my thread:
    Timing cover oil leak | PriusChat
    I was still within warranty and had it repaired free, but I was initially quoted $1700 for the repair. However, consensus on the forum was that if the oil leak is minimal, the repair can be postponed indefinitely. Just monitor your engine oil level and top off as needed. However, with a slow, seepage type leak, you will most likely not need to add oil between oil changes.
  11. hollyg
    hollyg New Member
    Franklin TN
    Thanks for the info. I will keep this in mind. I believe they were trying to squeeze all the money I don't have in my wallet. Just strange how it was $2600 to start with, then dropped to $1400. Really! Big difference in cost!
  12. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    If I were you I would start looking for a different place.
    Tande likes this.
  13. xliderider
    8,134
    3,273
    Honolulu, HI
    If I were her I'd just monitor it and let it be. There's probably not even enough oil leaking out to make it onto the covers underneath and drip out onto the ground.
  14. acadiel
    acadiel Junior Member
    39
    Illinois
    My 2010 timing gasket was replaced last year. Total was around $800, which warranty covered. Lakeland FL. Wow, that's quite a bit more they quoted you....
  15. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Alot of cars weep oil from the crank sensor. If I was weeping oil on that cover I would locate the crank sensor (has wire to it bottom of timing cover) and watch it.
  16. thauk
    thauk New Member
    California, USA
    I bought my used 2010 Prius IV 4 years ago. It currently has 68K miles on it. Took it in for an oil change today and was informed there is a leak from the timing chain housing. Normally $1700 to repair but it's under warranty still so it will cost $50. Never saw any leaks on driveway or from under vehicle. I think it's worth the $50 but seems odd that so many fail at such low mileage.
  17. edthefox5
    10,096
    4,833
    Clearwater, Florida
  18. MeGuinness
    MeGuinness Member
    217
    78
    UK
  19. Mendel Leisk
    41,012
    ^ Could you post another picture, backed out more? It's hard to understand orientation and location. Or just some more explanation: looking up, down, what side?
  20. MeGuinness
    MeGuinness Member
    217
    78
    UK
    1490880131745.jpg left side of engine
