Using PIP As A Generator
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by El Dobro, Oct 29, 2012.
  1. It all depends on what one must run in a emergency, everything in the house is rated in Watts, so you work up to 1500 or 2000 Watts. Perhaps the Kilowatt Meter would work in this direction also, if so, it would be a good aid. Your basically acting as your own power company.
    Corwyn likes this.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    2000 watts divided by 120 volts is..........16.666666666 amps.......over three times the max charge rate of the 12 volt aux battery
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    5 amps times 12 volts is 60 watts, right?
  4. I would simply keep my garage door slightly open to exhaust the gas, which is extremely minimal on a Prius.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    just install a metal pipe to the exhaust and vent it outside under your garage door
    Andyprius # 1 likes this.
  6. Please Kitty, what is that electronic formula you are using? 2000 watts is the potential that can be used, 120 Volts is the design Force. You cannot make up your own Ohms Law.
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    not making it up, since the purpose of the inverter is to supply 120 volts AND 2000 watts which would draw 16 amps
  8. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    The 5 A specification is a current limit using an external trickle charger.
    It means "do not use a quick charger to charge the 12V battery".
    Ken@Japan
    Tracksyde, lensovet and cwerdna like this.
  9. Except that 60 watt bulb is now working off of 120 V. I= E/R What current is the lightbulb drawing? You must know its resistance.
  10. Reedja42
    Reedja42 2012 Prius, Gen III, Barcelona Red, (FRED)
    253
    78
    Minimal compared to other vehicles, but just as toxic. What you propose is extremely dangerous! The exhaust from any vehicle, including the Prius, contains Carbon Monoxide and Carbon Dioxide among others. These gases will build up in your blood stream and replace the oxygen in your blood leading to death! Opening the garage door may in fact help the gas enter your home depending on the convections within your home. Why do you think people use car exhaust as a method of suicide? It can render you unconscious in minutes and unable to help yourself. I hope no one decides to take your advice about this.
  11. Wrong Math!
  12. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    They are far more likely to steal my neighbor's generator. Mostly a Prius acting as a generator looks exactly like any other Prius, with locked doors, no key and everything. Every so often the engine starts up, barely discernible on a normal night. Plus, if the lights go out, I am going out to see what's up with it; perfect alarm system. Besides, no one steals Prii.
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    12 volts
    don't you need the key fob next to the car to run the engine?
  14. Reedja42
    253
    78
    They might in an emergency.
  15. I also have a fire door to my washroom which is the other entrance to house. I can never smell fumes!
  16. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    No. You only need the fob to be inside the car to use the power button (to put it in ACC, READY, IG-ON modes). You can leave the car in READY mode and drive away w/o the fob. When they shut down, they won't be able to restart it, unless they have the fob. But hey, if the thief drives to a chop shop....
    It sounds like your dealer didn't show you/tell you about this at delivery.
  17. Reedja42
    253
    78
    That is why my generator is chained to the house. It's not going anywhere.
  18. NO, once the car is ready, you can take the fob upstairs.
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    From my Kill A Watt awhile ago I recorded 107.3 volts at 1264 watts the amperage was 11.9 checked my math, look's correct to me
  20. Reedja42
    253
    78
    You don't need to smell them to be effected by them. I could use my gas grill indoors and smell nothing but the food cooking and still die from the carbon gases. The Prius is actually more dangerous in this regard; because of the reduced particulates there is less to smell, increasing the danger.
