More Than A Dozen Fisker Karma Hybrids Caught Fire And Exploded In New Jersey Port After Sandy
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by spwolf, Oct 31, 2012.
  1. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    DB, Drinnovation responded with links to support his position.
    You responded by making insults.
    I'll take his facts backed up with references over your claims backed up with name calling.
  2. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Sorry, since you have not provided any links/sources to the fires you suggest how am I supposed to know what you mean. You made vague accusations and have presented no evidence it was caused by Volts or where GM was involved in the investigation. I guess I could see how to someone with 1st grade name calling skills my arguments with links to sources, might seem far advances (hence "6th grade" to some)
    Do you mean the fire's where media wanta-be sites like NLPC make acquisitions just because a volt was there, then never follow up after the there are actual facts.
    Are you refering to this one from conn
    Electric-Car Fire: Flaming Garage Shows Media Ignorance
    Or this one from NC
    Charger for Volt didn't spark Iredell garage fire, utilities say | CharlotteObserver.com
    Where in both cases the local fire officials said the volt had nothing to do with the fire?
    Unless you can show reputable sources suggesting a coverup, you seem to be the one in denial
  3. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Another 6 grader response. Government Motors is what it is. The reality is (an no surprise there), that they have lasted as long as they have.
    OOPS, there I go again, putting out (alleged) insults. But maybe, just maybe the real issues is: "thin skinned individuals" ?
    Just food for thought.
    DBCassidy
  4. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    I'm waiting to see if this thread gets back on the topic of Fiskers and Hurricane Sandy. Failing that, there are Volt forums just ripe your your discussion. Failing that, I close this thread.
    Zythryn likes this.
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    austingreen likes this.
  6. John H
    John H Senior Member
    2,208
    558
    So it seems that Fiskars are not unique in their vulnerability to 13 feet of seawater.
  7. John H
    2,208
    558
  8. austingreen
    austingreen Senior Member
    13,671
    4,209
    Austin, TX, USA
  9. fotomoto
    fotomoto Senior Member
    5,634
    3,812
    So. Texas
    Besides the cars at the port, I heard a report this morning that as many as 1/4 million used cars are considered "total loss" so new cars sales should bubble in the area.
  10. bwilson4web
    16,201
    Source: The Associated Press: Claims about flood-damaged cars aren't true
    Tip #8 - Look for a scorched earth outline of a car with large lumps of melted metal and glass.
  11. innerpri
    innerpri Junior Member
    55
    MD
