Film on inside of front window.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by larryakoch, Nov 5, 2012.
  1. larryakoch
    larryakoch Junior Member
    82
    Pomona, ca
    What causes that glaze that collect inside my front window that I have to remove every couple days? Is there any way to prevent it. Early morning driving into direct sunlight I'm almost completely blinded.
  2. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Its offgases from all the plastics in the car. All cars do it to some extent.
    larryakoch likes this.
  3. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Following F8L's suggestion I run with the driver's window & right rear window down a bit. Some ventilation should reduce the problem. That film is a PITA. I haven't found an easy way to remove it.
  4. bisco
    51,851
    and you're breathing it all the time.:eek:
  5. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    B&W newsprint, your favorite glass cleaner, and three passes will keep it clean for a long time. Run the defroster and/or a/c to keep the interior air dehumidified.
    Andyprius # 1 likes this.
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    If you park in a place where you can leave the windows down a crack when the car is in the sun, it makes even more difference.
    Once you get the greasy film on your windows, Stoner's glass cleaner cuts the film off better than anything else I have tried.
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    If you have a chance, leave your car parked in the sun with the windows cracked open a bit. Let the heat of the Sun boil all the vapors out of the plastics that make up the inside of your car!. All of the above mentioned cleaners cut the film with a little bit of elbow grease! Just noticed you are from Pomona, I think with the Santa Annas this week, it be would be a good week to bake a new car!
  8. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    ...this is an FAQ on auto threads and the one answer is: try the top notch glass cleaner, think it's called Invisible Glass, you can get it at Walmart. Really helps, problem is it's really invisible, cannot find my bottle of it.
    drsacha and Adam Leibovitch like this.
  9. genetiix
    genetiix Member
    123
    49
    San Jose, CA
    I picked up another bottle at target yesterday. They had the spray and the aerosol.
