2012-2015 Prius PHV: Custom PIDs for Torque Android App
Discussion in 'OBDII Android App' started by usbseawolf2000, Mar 10, 2012.
  1. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    Hey guys,
    Im really sorry but I didnt read through the whole thread. I have been reading threads for a couple hours now trying to find a pid for my new pip. I just traded in my tundra and 08 prius about 5 hours ago.
    Im loving the car but Id like my torque app back. All this tech stuff is way over my head otherwise I would help you guys.
    Please let me know if there is a working version somewhere.
  2. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Hi Jimbo69ny,
    The current version was posted in post #42.
    Vincent
  3. Jimbo69ny
    712
    107
    Ithaca, NY
    Thank you Vincent but all I see is a link to a spreadsheet. Forgive me, but I dont understand.
  4. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    When you were running Torque with your 2008 Prius, you downloaded the custom list of PIDs, right? The spreadsheet is the list of PIDs that work on the 2012 PiP.
    If you've never done that before, basically, you need to get the spreadsheet that Vincent referenced onto your Android device. Then, run Torque and under Settings you can install a custom PID list.
  5. Jimbo69ny
    712
    107
    Ithaca, NY
    I see two files. One dated 10/9/11 and another 4/24/12. Do I need to add both to my phone or just the newer one?
  6. Jimbo69ny
    712
    107
    Ithaca, NY
    I added both. Looks like that did it. Thank you very much!!
  7. vincent1449p
    894
    332
    Singapore
    Both are for the non-plugin Prius, you should either download the spreadsheet that I linked and convert to CSV or you can use Tracksyde's CSV file.
    Vincent
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Thanks, I edited my first post and linked it to your file. This should make it easier for the new users.
    Tracksyde likes this.
  9. lensovet
    2,615
    496
    Burlington, NJ
    so just to clarify, the link in your original post is the most current one, correct?
  10. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I think so, unless Vincent has a more updated one.
  11. lensovet
    2,615
    496
    Burlington, NJ
    might be good to put a "last update" line on that first post then
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Just did. Thanks for the suggestion.
  13. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    As far as I know, that was the last one Vincent posted and its the one I'm using also.
  14. priusito_de_mi_vida
    priusito_de_mi_vida Junior Member
    78
    Spain
    Sorry, wrote in the wrong thread.
  15. vincent1449p
    894
    332
    Singapore
    Hi Tracksyde / usbseawolf2000,
    Here is my latest updates.
    Vincent
    usbseawolf2000 likes this.
  16. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    Thanks Vincent!
    Just got my BT OBDII device Saturday- set up Torque on the Nexus7 yesterday.
    Excellent all around!
  17. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    This one caught my eye. I wonder if I can use it to turn on the windshield defrost and keep the ICE off. :D
  18. vincent1449p
    894
    332
    Singapore
    I doubt it, mode 21 are Read Only mode, it only returns the status. Mode 3x commands may be possible but you need to know exactly the address or the offsets, sending the wrong command can cripple your car.
    Vincent
    lensovet likes this.
  19. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Vincent, I think these are in reverse.
    • HV battery discharge control
    • HV battery charge control
    The discharge should be a positive number, like the other HV battery power PIDs. For example, Power Resource IB (battery pack current) is positive when it is draining.
    vincent1449p likes this.
  20. lensovet
    2,615
    496
    Burlington, NJ
    Btw, is there a way to read out the individual pressure readings on the tires?
