Run Fan Without Heat or AC?
Discussion in 'Gen 3 Prius Main Forum' started by Metalman, Nov 11, 2012.
  1. Metalman
    Metalman Member
    107
    17
    Summer, KY; Winter FL
    I checked the search function and got a error message.
    There are times when I'd like to run the fan for cabin ventilation and when I press the fan button, the temperature setting shows up on the display. I assume the vehicle will either heat or cool the air until it matches the temperature setting. I do not want the engine or AC to be used to change the temperature of the air. What I'd like to see is the fan running and no temperature setting on the left of the display.
  2. Adam Leibovitch
    498
    102
    Just turn off the AC button and set the temperature below the cabin temperature.
  3. bisco
    51,843
    wait, you've had your car for 2 years and you don't know how to do this?:)
  4. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    What I do is: 1) AC button off (No AC part); 2) Set temp target to LO (No heat part).
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I press up on the fan speed button. I then press the temperature to the desired temperature. A/C is not on and Auto is not on. AFAIK, temperature is not being regulated. The temperature you see on the screen is just the level of heat coming in like a rotary knob on other cars. Usually, I leave this on LO.
  6. Metalman
    Metalman Member
    107
    17
    I appreciate the help on this one. We only drive the car in the summer and haven't had a concern about driving without the AC until recently.
    bisco, thanks for your especially constructive comment.:)
  7. Les_PL
    Les_PL Active Member
    317
    249
    Gdynia, PL
    This is exactly what I do. With AUTO off. The only thing is that I have to turn on the windshield defogging frequently. In present weather condition (ambient temperature now oscillates in range 0-10 Celsius [32-50F] ) the windshield becomes foggy quiet fast. Did not found yet what is better - maintaining the continuous blow with some heating or switch on-off defogging (which engages AC every time). I think first option.
  8. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    On our "v" wagon...I turn the temp. setting to "LO."....AC off....fresh air in....set fan speed....
  9. bisco
    51,843
    just pullin' your chain man.:cool:
