The 06 lights are really bright
Discussion in 'Gen 2 Prius Main Forum' started by windstrings, Jan 16, 2006.
  1. windstrings
    6,280
    378
    Central Texas
    I was in front of Tumbleweed after a meeting and it was cloudy and misty and all the cars surrounding him on the 4 lane freeway we were on yuckey "yellow" and dull compared to his prius.
    I really really like the frequency they chose.... its not blue, nor green... but just striking pure hot white like the sun on a bright day.
    I was very impressed!
    Second Thought.. his may be the 05... I remember he had 9K on it already... well if so thats good for the 05's too!..
    I'm not sure there could be any improvement to them?
  2. habel
    habel New Member
    230
    Oslo, Norway
    Hi Windstrings!
    Is this HID's or the std. light??
  3. KTPhil
    KTPhil Active Member
    1,379
    22
    Probably the difference between HID and halogen.
  4. windstrings
    6,280
    378
    Central Texas
    You know.. I guess we will have to ask him.. I don't really know.. he didn't mention anything about t them being anything but stock at the meeting?
  5. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    My car is an 05 and they are HID headlights. I doubt if they changed the lights any for 06 though. I think they are a very worthwhile option and I was disappointed to see you have to buy the nav and upgraded audio to get them in 06.
    They seem to show the road better than any other lights I have had and as far as I can tell they are aimed correctly, I've never had anyone flash their lights at me when they were on dim.
    Edit: the meetup was great, good group
  6. Rocketeir
    Rocketeir New Member
    28
    Edgewater, Florida
    You do get HID with option package 6 which does not have the NAV. It does have the JBL audio though.
    Steve
  7. windstrings
    6,280
    378
    Central Texas
    Yea.. if you click our link at the top in red for the 2006 prius info.
    It shows the HID headlights are now included if you have package #6 or higher.
    Kewl!... I like it!... they really are impressive!... it makes everything else look like a flashlight!
    Its not so much that they have massive candlepower that hurts your eyes when you look at it, but its more that its blinding white in its frequency. I"m sure it really helps turn the night into daylight with appropriate colors coming back to life when the light hits objects from thier dark dullness as the light hits them!
  8. Zacher
    Zacher New Member
    236
    OR
    Ok, since you guys are so happy but my HIDs seem so lame to me (aimed too close, even for speed-limit driving) I have to ask again: Has anyone had their HIDs re-aimed for them?
    (Bummed I missed the meetup for the purposes of meeting y'all and comparing headlight aims, too!)
  9. windstrings
    6,280
    378
    Central Texas
    Maybe you can make the next one!... make sure you go sign up so you know the scoop.... I don't know if tumbleweed complains of the same thing as you... but while I was in front of him.. they looked great in my rearview!
  10. tumbleweed
    4,067
    692
    Eastern Oregon
    I have not had a problem so apparently mine came aimed correctly. But others have, and there have been posts on the subject. I haven't searched for them but you may be able to find them.
    Here's what I remember: You can't aim them yourself because there is a special procedure due to the level sensor which is located back by the rear axel somewhere. In fact I think someone said the level sensor was the problem with theirs being off, so it needs to be checked before the lights are aimed.
    You may be able to get them aimed under the waranty, if they were always that way they certainly should be covered.
  11. KTPhil
    1,379
    22
    You can do it yourself, but first check the sensor on the rear axle.
  12. KTPhil
    1,379
    22
    Here is an excerpt from the European VW Bug aiming instructions for 1963. This is the same as for the headlamp reflector/lens pattern used on the Prius (certainly for the HIDs, and apparently for the halogens as well).
    The measurements (height above floor, between headlamps) are different on the Prius, but the idea is the same: they should be aimed slightly downward (2 inches at a distance of 15-20 feet).
    You can check this by parking in front of a wall on a flat paved area like a parking lot. Then slowly (so as not to rock the car) back up and see if the horizontal line between light and dark slowly drops. You are pretty close if this happens, and if at 20 feet you have at least a two inch drop.
    The attachment shows the aim for the left lamp, with the right covered up; the right would be similarly aimed to the right cross.
    [attachmentid=1857]
    Here is a manual excerpt showing the Prius aiming screw (accessible after removing the black plastic radiator area top cover:
    [attachmentid=1858]
  13. windstrings
    6,280
    378
    Central Texas
    wow.. with this much trouble to replace.. I hope these last a long long time!
    I've read they last 10 times longer than halogen?
    does anyone have a link that shows the specs of the prius HID's.
    They may be the same for the lexus?
    Here are some interesting links I found:
    http://www.greenhybrid.com/discuss/xeons-h...he-hh.5160.html
    http://priuschat.com/index.php?showtopic=1...10&#entry179390
  14. KTPhil
    1,379
    22
    Trouble? This is just aiming, not bulb replacement. All cars are similar. Below is the 1971 VW Fastback aiming instructions for the American sealed beams; most American cars used this pattern for decades until about the 1990s, and some still do. I think the halogen Prius headlamps share the HID pattern above, though.
    [attachmentid=1859]
