What did you all do to break in the 2012 Prius?
Discussion in 'Gen 3 Prius Main Forum' started by priusbee, Nov 19, 2012.
  1. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    I hope they give frequent flyer miles where you buy oil and filters.
  2. WE0H
    WE0H Senior Member
    3,247
    528
    We buy new vehicles every 5 or 6 years and they get a max of 5k miles a year each. A oil change once a year that way x5 vehicles isn't much oil :)
    Mike
    Mobile on my Asus
  3. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Park it at a seedy neighborhood at night, leave your wallet on the dashboard and it will get broken in, without your own effort.
    mad-dog-one likes this.
  4. bwilson4web
    16,126
    On the way home, I ran a series of 10 mile, benchmarks, both directions, at different speeds to measure the MPG vs. mph. I finished the high-speed, 75 mph, ones two days later.
  5. mad-dog-one
    1,181
    421
    Whereabouts Unknown
    Put enough money in that wallet an I'll break it in for you, myself.
  6. JE Sukara
    JE Sukara Junior Member
    17
    San Francisco Bay Area
    2018 Prius
    My dealer said to do first oil change at 5,000. Is that wrong??!
    JMD likes this.
  7. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Every 10,000 miles is Toyota's schedule.
  8. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    5,000 mile oil change for harsh conditions is also recommended. Harsh can be a dusty environment or long idle times. Today's synthitic oil can go the distance. Also keep in mind the engine I not running when the EV is on so the wear and tear is less. Do what makes you comfortable.
    WE0H likes this.
  9. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Better question is, did they upsell you and made you pay for the oil at 5K, or did they cover it under ToyotaCare?
  10. WE0H
    WE0H Senior Member
    3,247
    528
    I can't give my Toyota Care away can I? I have no need for it as my vehicle only gets ~1k-5k miles per year put on it and no way can I leave it that long waiting to add up enough miles for a 10k mile oil change. I have to do 'em myself :)
    Mike
  11. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Doubt it. You can try asking for them to just give your 5 QTs of oil and the filter. I doubt they will entertain the idea, I don't know if they will be able to bill Toyota this way, but you can try.
  12. JMD
    3,779
    1,282
    I remember the Sludge Scare. Prius is not one of those effected cars.
    Causes of Sludge
    ■Faulty head gasket, allowing coolant to leak into oil system
    ■Unburned gasoline contaminating oil
    ■Inadequate oil circulation
    ■Infrequent changes of oil and filter
    ■Poor quality or nondetergent oil
    ■Oxides of nitrogen from emissions system contaminate oil
    ■Engine runs too cool in spots, causing condensation buildup inside crankcase
    ■Engine runs too hot in spots, causing oil to break down faster
    ■Seal on oil filler cap fails, allowing moisture to enter engine through valve cover
    ■Too many short trips or frequent driving under adverse conditions
    Cars impacted.
    ■Camry, built August 1996 to July 2001
    ■Camry Solara, built June 1998 to May 2001
    ■Sienna, built July 1997 to May 2001
    ■Avalon, built July 1996 to May 2001
    ■Celica, 4-cylinder, built August 1996 to April 1999
    ■Highlander, built November 2000 to July 2001
    ■Lexus ES 300, built August 1998 to July 2001
    ■Lexus RX 300, built January 1998 to July 2001
    Source: Toyota Motor Sales U.S.A.
  13. WE0H
    WE0H Senior Member
    3,247
    528
    I guess I'll never have a car in that category [​IMG]
    Sum people think I change my oil too often :)
    MIke
    JMD likes this.
  14. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Gentle for the 1st 600 miles, vary your speed and don't use the Cruise control, after 600 miles, just drive it .
    WE0H likes this.
