Windshield Wipers too short!
Discussion in 'Prius c Technical Discussion' started by AliIzad, Nov 17, 2012.
  1. AliIzad
    AliIzad Member
    170
    72
    Southern California
    New here so please forgive me if this has been asked before.
    Is anyone else annoyed by the fact that the Prius C's windshield wipers have a gap between the drivers and passengers side? Water keeps blowing back up onto the windshield. Does anyone know if there is a solution?
    Thanks!
  2. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    Blowing back onto the windshield? I have no idea what you're talking about. The wipers on the C are awesome; they clear the glass very effectively and have almost no splash-back. Are yours installed wrong?
    What cars are you used to where the wipers overlap, and how so; during wiping, or at rest?
    RocMills likes this.
  3. AliIzad
    AliIzad Member
    170
    72
    Southern California
    I have to assume they are installed properly, have not touched them since I got the car. And yes you are correct, they work perfectly. However, if you look at most cars, the wipers are slightly offset from each other so that there is allowance for a bit of overlap. On the prius C, (at least on mine) there is a slight gap (about 1") between the top of the drivers blade and the bottom of the passengers blade which leaves an area that is not covered by either blade. As you drive, water sprays up between the gap. I checked a few other C's at the dealer and they were the same. Considering what a great car the C is, this is really a non-issue. I was just curious what others experience was. If for some reason mine is the only one like this, then it is what it is.
  4. Ryephile
    418
    151
    24
    Metro Detroit
    Overlap during the wipe stroke, yes that's normal, and happens on my C just fine. Overlap at rest is not normal unless you're used to mirror-imaged wipers like on the current Honda Civic or those awful GM vacuum-cleaner minivans from the 90's. According to TireRack, the wipers are 28" for driver-side and 14" for passenger side. Measure yours to see if these are correct.
  5. AliIzad
    AliIzad Member
    170
    72
    Southern California
    Thanks for the info Ryephile. Will do.
  6. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Oh god I hate those style wipers the new Focus does it GM is going it again with a buick.
    I call them minivan wipers because thats all you ever really seem them on. Well used too,
  7. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    My boyfriend's Civic had those, and they seemed to work really well. I liked them.
  8. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    You will learn to ignore it. Or not. Your choice.
  9. AliIzad
    AliIzad Member
    170
    72
    Southern California
    Already ignoring it. The car is too good to worry about small issues.
  10. firstrival
    firstrival Member
    102
    It has rained heavily the past few days in Northern California and I have not noticed any problems.
  11. F8L
    19,011
    4,083
    Grass Valley, CA.
    Maybe RainX would help?
  12. Oldwolf
    Oldwolf Prius Enthusiast
    825
    110
    NC
    2016 Prius v wagon
    I need a picture because I have no idea what you guys are talking about. I have not noticed anything wrong with the wiping area of my blades.
  13. KaliforniaKid
    KaliforniaKid 2013 Prius v Five 2012 Priuc c Four
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    Is this what we're talking about? That skinny little area both wipers miss by the passenger side of the windshield?
    You could go with a 29" wiper blade on the driver's side if it bugs you that much. It'll be long enough to overlap and stay above the passenger side wiper blade which is at it's maximum length right up next to the windshield pillar.
    Ryephile and Oldwolf like this.
  14. Oldwolf
    825
    110
    NC
    2016 Prius v wagon
    That's exactly what I needed to see KaliforniaKid. Thanks!
  15. Ashley7
    545
    222
    Oregon
    2019 Prius
    Isn't a little triangle like that pretty typical on most cars? This one is smaller than most I've seen. I can't help but think there's something else going on with OP's wipers (or OP's perception of the rain). Something about it blowing back onto the windshield? Maybe the wind is different in Laguna Beach :)
    Ryephile likes this.
  16. Ryephile
    418
    151
    24
    Metro Detroit
    +1 to everything. Most cars have a much bigger triangle; IMO we're fortunate the wipers are as good as they are. I've owned some cars with some seriously crappy wipers.
  17. born_again
    born_again Member
    103
    47
    Rancho Palos Verdes, CA
    This morning I was able to simulate OP's issue:
    LOL.
  18. Ashley7
    545
    222
    Oregon
    2019 Prius
    Interesting, that looks like what happens when I use the spray. They seem to leak a little extra after the wipers have gone over, which blows up onto the windshield like that.
  19. Ryephile
    418
    151
    24
    Metro Detroit
    Is that seriously considered an "issue"? Quick, somebody get me a Consumer Reports survey! :ROFLMAO:
  20. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    i just keep wiping until it's gone... :eek:
    TC400, RocMills and Rob.au like this.
