Where does the Smart Key go?
Discussion in 'Gen 3 Prius Main Forum' started by mikedow, Nov 28, 2012.
  1. mikedow
    mikedow Junior Member
    22
    West Palm Beach, Florida
    I recently traded in my 2007 Prius for a 2012 model 4. I assumed the black rectangle below the power button was where you put the fob in the event the battery died. Apparently not so, because the rectangle was simply a cover. Where do you put the key if the batter in your fob gets wet or dies? It scares me because this has happed in the past.
  2. gliderman
    gliderman Active Member
    751
    225
    over to the start button
  3. El Dobro
    El Dobro A Member
    7,086
    3,263
    Yep, you hold the fob up to the start button until the green light on the button comes on, then you press it. It's covered in the owner's manual.
  4. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    I don't know about the Gen 2, but in the Gen 3, you hold it near the start button.
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    You hold it over the button and say: "The power of the fob compels you!"
