From 'ON' mode to 'Accessory' mode directly
Discussion in 'Prius v Main Forum' started by umichioe, Nov 14, 2012.
  1. umichioe
    umichioe Junior Member
    77
    With the smart key system, is there any way to go from 'ON' mode to 'Accessory' mode directly?
    I frequently want to listen to music while waiting for people. Turn it off and then back to Accessory mode is a little annoying, especially with bluetooth streaming.
  2. Alice Mya
    Alice Mya Junior Member
    42
    I thought it was better to leave it in ready cause acc. mode drains the battery I thought. Correct me if I'm wrong.
  3. umichioe
    77
    Interesting suggestion. Never tried leaving it on for more than couple min. Will stay in READY restart the engine? Don't want to waste gas.
    ACC mode will use some battery, but the head unit should not use too much.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    You're better off leaving it/putting it in READY mode. I wouldn't leave it in ACC nor IG-ON for long. At least on Gen 2, IG-ON appears to use more power due to the voltage dropping from ACC to IG-ON.
    Yes, leaving it in READY will cause the engine to restart if the HV battery is too low. I'd rather have that than flattening the 12 volt.
  5. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    That's what I've understood as well.
    If you leave it in ready mode, the 12v battery will draw power from the traction battery to keep itself topped up as you listen to the radio. If outside temps are warm and your not using AC or the heater, fan off, you should be able to sit in ready mode for quite awhile before the engine will need to run to charge the traction battery or warm itself up.
    So IMO there's not much point in using accessory mode to save gas unless its really cold outside(below 32f), and in that case you probably wouldn't want to be sitting in a cold car very long anyway so go ahead and use the accessory mode for a few minutes while you wait.
  6. Adam H
    Adam H Junior Member
    61
    Where did you read that the 12 v battery charges from the traction battery?
    Normally a 12 volt auto battery can power accessories for a long time without signs of discharge.
  7. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    I just assumed that was the case.
    How else would the 12v battery recharge itself? Prius does not have an alternator/generator as do conventional automobiles.
    I assumed the 12v battery gets its charge from some kind of step down connection from the traction battery.
    Imagine how a 12v battery is used to power accessories in a Toyota Corolla. That car has an alternator to charge the 12v battery while the car is running. When you shut the car off you can listen to the radio for quite awhile with no worries of the battery going dead.
    Now replace the word "alternator" with "traction battery" and "Corolla" with "Prius". That's how I understand it.
    To further clear up the misunderstanding, I completely agree, the 12v battery used to run accessories like the radio will last for awhile just sitting in "accessory mode". I never said otherwise.
    Adam H likes this.
  8. Adam H
    61
    Looks like you're right. Here's something I found on it:
    Automobile Repair/Toyota/Prius - Wikibooks, open books for an open world
    jonb505 likes this.
  9. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
  10. like2bike
    like2bike Junior Member
    Melville, NY
    2014 Prius v wagon
    The module for lowering the DC voltage is called a DC/DC converter (Step-down is an AC term). The manual does address the issue of leaving the car in ACCESSORY too long (page 178):
    If the vehicle is left in ACCESSORY mode for more than 20 minutes or ON
    mode (the hybrid system is not operating) for more than an hour with the
    shift position in P, the “POWER” switch will automatically turn off. However,
    this function cannot entirely prevent the 12-volt battery from discharging. Do
    not leave the vehicle with the “POWER” switch in ACCESSORY or ON mode
    for long periods of time when the hybrid system is not operating.
  11. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    I just monitor the voltage on my Scangauge II and when it begins to drop I put the car on "READY". Only happened once, while waiting for my wife, who was shopping - natch.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    Leave it in Ready mode, heat/AC off and press the EV button. The ICE will only start if the traction battery gets low.
    mtl_sienna likes this.
  13. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    OK. Here's my view on the matter, as a Gen 2 owner.
    1. Yes, in Acc mode, the 12v battery can become depleted slowly, as it will not be recharged from the traction battery. I regularly use the radio in Acc mode, for 15-20 minutes, with no problems.
    There is a diagnostic mode that you can enable if you want, that shows the actual voltage of the 12v battery, so you could monitor this if you wanted.
    2. However, if you are in Ready mode, the car will definitely use a LOT more power, powering the inverter etc. You can watch the power bars for the traction battery and you will see that they go down fairly quickly.
    So although you will not flatten the 12v battery while in Ready mode, you will take a hit on your MPG if you sit in Ready mode for any period of time. Even if the ICE doesn't start, the ICE will have to recharge the lost traction power when you start to drive.
    Also, it doesn't seem the best use of a Super Low Emissions Vehicle to be pumping out CO2 and exhaust gasses just to power your in-car entertainment, to me, to be honest.
    #13 GT4Prius, Jan 30, 2015
  14. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    This is all well and good when your 12V battery is healthy but several on here have been blind-sided by the voltage dropping to the point of disabling the vehicle after doing just what you describe (listening to the radio for 20 minutes). Admittedly, sometimes there's user error involved (leaving the headlights on by accident).
    If you feel lucky, go ahead and sit in accessory mode for however long you want but be aware that some day you might end up with a problem.
  15. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    No need to trust to luck! Get the 12v battery checked out (or check it out yourself),to make sure it's healthy, and as I said, use the inbuilt 12v battery voltage monitoring mode while you are in Acc mode.
    I replaced my 12v battery a couple of years ago when it started to fail, but before it became a problem. It was apparent to me that it wasn't right, and the dealer confirmed this. So I did have some warning.
    Doing that saves you money on fuel and saves you pumping out CO2 unnecessarily, in a vehicle specifically designed to minimise that.
    Leaving the headlights on is another issue altogether.
