How long does the battery last on a PIP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by priusenvious1, Dec 5, 2012.
  1. priusenvious1
    priusenvious1 Member
    325
    37
    LA
    How many miles?
  2. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    All of yours posts are impressively ambiguous.
  3. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Nobody knows. In CARB states, it's guaranteed to last 10'years or 150K miles. In reality, it'll probably be north of 200K easily.
  4. Adam Leibovitch
    498
    102
    Between 10.5 miles and 14.0 miles depending on how I drive and the route.
  5. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    It will last until Toyota recycles it.
    How long any one charge will last has been answered as well as how long it can be recharged. I think this completes all possible answers to a really vauge question. (The atoms last forever)
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    Judging from the track record, it'll last longer than Toyota's 10 years / 150k miles warranty.
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    To cover another ambiguity, the auxiliary battery is small and is not meant to power the car when off. So if listening to the radio while parked, do it briefly, or be in READY. Lifetime can be a decade or more. Preventative maintenance is normal climates is 5-6 years. In harsher climates, 3-5 years. Sooner if a high drain is left on and depletes it.
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    what about the battery in the key fob?:D
  9. 3PriusMike
    3,069
    2,400
    Silicon Valley
    My previous Prius key fobs have lasted about 40K miles. But I have low mileage (about 8K miles/year). I'd bet that someone who drives 20K miles per year would get 100K miles on a key fob.
    Mike
  10. 3PriusMike
    3,069
    2,400
    Silicon Valley
    Why would a harsher climate matter much? The 12v battery does not crank the car...it just power the computer to start it.
    Mike
  11. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Someone posted a chart that shows a bell curve of PIP battery life based on aging and forecast technology. Some of it is based on environment and cooling. The PIP uses fans to keep the Battery cool. A PIP parked outside in the Desert with summer heat at 120 degrees will not have the same life span as one parket near the ocean with an average temp of 70 degrees, and not as good as a garaged car with some environmental controls. The warranty is 10 years or 150,000 miles in the CARB states. A decade is about the time when they start to fail if not taken care of. If not covered by warranty a Salvage battery costs about $500 + labor to install, a rebuilt about $2,000 + labor and new I beleive $3,500 + Labor . I'm not a mechanic or expert but this some of the info traveling around PriusChat that I recall.
  12. JMD
    3,779
    1,282
    12V battery is about 5-7 years based on environment.
  13. JMD
    3,779
    1,282
    Keyfob not very long if you leave it in your pocket and wash the pants in the washing machine. LOL
  14. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Hot and cold are the enemy of batteries. Thankfully the battery is in the cabin, but it still gets cold. I have measured way below freezing temperatures in my Prius in the cabin before. On hot days when it might be 100F out, it is probably 110F+ inside the car. That is bad for a battery. On one of my ski weekends last season the Prius was parked outside for 3 nights with daytime highs just above freezing and nightly lows closer to -20F. That is bad for the battery.
    If you garage it 100% of the time, not a problem. But "harsh" climates will lower the lifespan of a battery.
  15. lensovet
    2,615
    496
    Burlington, NJ
    He's talking about the aux battery, not the HV battery.
    Btw, pip manual says never to store the car below -40 and to not charge in temperatures below -22°F
  16. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yes, but this applies to all batteries. Leave your cell phone in the car or the keyfob outside, same difference. Weather doesn't care what the battery is used for!
  17. lensovet
    2,615
    496
    Burlington, NJ
    Well, cellphone screen will probably get destroyed sooner lol
  18. JMD
    3,779
    1,282
    Someone just posted the the Volt has a liquid cooled system for the battery, the Prius has a Fan based system and the Leaf has a passive cooling system. You may recall the owners report saying do not block the vent located in the rear seating area. There are reports that the leaf located in Palm Springs and Phoenix area are getting early battery failures in part due to the excessive heat and passive cooling system. This is covered under warranty. Should expect to see some design modifications if they have not occured already.
  19. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    Regular Prius has a battery fan blower. PiP has upgraded twin blowers.
    lensovet, JMD and SJ PiP like this.
  20. JMD
    3,779
    1,282
    After owning a few cars some decade long and others just 3 or 4 years I'm starting to think that the best car experiences are the cars I own less than 5 years. I beleieve someone said the sweet spot on resale is 3 years and less than 60,000 miles. I can say that most cars made today (Most not all) can go 5 years on just routine maintenance. If you sell the car before that you avoid all the repair bills and headaches assocaited with long term ownership. I'm sure some with mechanical abilities and the right tools welcome those situations, but for someone like me if I can avoid it I'm a happy guy.
