2012 "SETTINGS" for Fuel consumption on each fuel up?
Discussion in 'Gen 3 Prius Fuel Economy' started by priusbee, Dec 11, 2012.
  1. priusbee
    priusbee Member
    125
    SF Bay Area
    What do you guys do on each fuel up?
    Sometime, you have 2 bars or 3 bars left in the fuel tank. What do you do?
    How does that come into the computer calculation?
    I would like to hear from you folks on using this and if you know it, explains how all that calculation works when it display that information when we look at the consumption and usage.
    Essentially, I would like to know the proper procedure entering the information on each fuel up, so it is correct when displaying the fuel consumption.
    Thanks!
  2. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    I am not sure I understand what you are asking. My Prius uses the volume of fuel in the fuel injector to calculate MPG, not any reading from the pump.
    If you are wanting a third party MPG tracker, I use Fuelly.com
  3. HprDad
    HprDad Junior Member
    72
    17
    WI
    What many folks do, myself included, is to reset one of the trip odometers at each fuel up, which makes for a convenient MPG calculation for that tank. The cumulative monthly fuel usage runs automatically, with no settings required at each fillup. I don't bother with the cost per gallon setting that pops up after a fillup, it is only for comparing costs to another car.
  4. theotherone
    theotherone Junior Member
    67
    24
    Greenville, SC.
    I basically "zero-out" the Trip A and Trip B settings every time I fill up my tank. I generally like to know what my average MPG are out of each tank & how many miles I get out of each tank.
  5. walter Lee
    1,126
    376
    Maryland
    For the last few tanks, I have driven my 2010 Prius about 70 - 100 miles after the first beep and about 30-60 miles after MTE=zero and the last bar on the MFD is flashing. The first beep normally occurs between 430-630 miles(about 9 gallons have been spent and about 2 gallons remains in the tank at the first beep). At each fillup I zero out Odometer Trip A, I zero out Odometer Trip B, I reset my first ScangaugeII fillup/fuel used & price per gallon, and I reset my second ScangaugeII fillup/fuel used & price per gallon. I write into my Prius' logbook all the information needed for my fuelly and cleanmpg mileage logs: gallons pumped, (Trip A/B ) mileage traveled, cost per gallon, type of fuel, average speed estimated.
    priusbee likes this.
