Tire Pressue gauge works
Discussion in 'Gen 2 Prius Main Forum' started by AlphaTeam, Jan 19, 2006.
  1. AlphaTeam
    AlphaTeam Member
    643
    Earth
    Yesterday on the way home from work. Pressure light came on...get home check it out. I hear a SSSSSsssss. Great..I see a staple in the tire. I quickly drive to my usual tire shop. "That is too close to the edge it is unrepairable". "So for $85 and 30 minutes you can be back on the road". 1st payment is just due...yuppie!!!
  2. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    Well that's good to hear (about it working, not about the flat...). I've started to wonder after reading some posts about people switching wheels and not having he light come on for 30-40 miles, or ever at times. Maybe the system is sometimes disabling the system automatically when the sensors all vanish.
  3. AlphaTeam
    AlphaTeam Member
    643
    Earth
    Mine was down to 10 PSI when I got home. I don't know what it was when I first noticed though.
  4. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    I know the 06s don't have the Roadside Assistance package, but do they also not have the Road Hazard Warrantee? On an 04/05 you would get the new tire (or tire and wheel if the wheel is damaged) for free.
    They reimbursed me for repair on the one flat I've had.
  5. AlphaTeam
    AlphaTeam Member
    643
    Earth
    I called Toyota before I told them to go ahead with it and they said no it was not covered.
  6. augustson
    augustson New Member
    93
    SE Georgia
    My '06 came with Roadside Assistance. It was mentioned in one of the little mini-guides that came with my car AND I confirmed it with the dealer. He said all of the '06 Prius models came with it.
  7. DaveSheremata
    DaveSheremata New Member
    249
    Arlington, Virginia
    Hmm. I read a great post here a while back that described how the TPMS works - something about monitoring the rotation of each wheel and comparing them to each other - if one wheel is lower pressure than the other at the same end of the vehicle, it will rotate faster because it's effective radius to the ground is smaller and will operate as though it has a smaller diameter. I speculate that if there's no sensor on the wheels, the TPMS is waiting for wheel rotation "clicks" that never happen and so the wheels are still technically "in sync" and therefor considered equally pressured.
    I imagine one of the main reasons that Toyota put the system in the first place is to help address too many claims of lower than expected fuel economy. e.g., Tires inflated to 28psi might look fine from the outside, but once a driver is in the seat weighting down one side of the car, the weight would be enough to trigger the TPMS's warning light
    AlphaTeam - are you guys aren't in NYC are you? I was blown away last year with a flat there that there are "fix a flat" places all over Brooklyn - but they're ususally a lot cheaper and quicker than your experience.... $35 for a "new" truck tire :)
    Dang, I can't wait till the weekend when I get my Prius!
    Dave
  8. gbgirl79
    gbgirl79 New Member
    44
    One thing Ive learned throughout the week of owning my Prius is that half the dealership people have NO CLUE what is going on in regards to the Prius and will lie to you just to get you off the phone.
    I was told i do not have Roadside Assistance, by the Roadside Assistance people. So I know it is true. But I do have a tire warranty and a pamphlet which was included with my booklets, so you should have some kind of coverage I would beleive. But if you just ran over a nail on the highway, alot of the times they wont pay for something like that.
  9. AlphaTeam
    AlphaTeam Member
    643
    Earth
    The place I went to in Grand Rapids, Michigan is the place I've been going to for years, Discount Tire Compnay. They have always done good by me and they said it could not be fixed. And if they did it would not last long.
    I called Road Side assistance and they said no even though it came in my packet. I called the dealer and he called Toyota and they said no to it also.
  10. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    that was my post, and it was describing the OTHER toyota TPMS system, the one that's on every other car that has the system, but they decided to put the truck system on the prius. :huh:
    the prius has sensors in the valve stems.
  11. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    Nope. Old news. The '06 actually has little pressure sensors in each wheel. They radio back the pressure of each tire to the system. The rotation system has some drawbacks and Toyota did not use it on the '06 Prius.
  12. KTPhil
    KTPhil Active Member
    1,379
    22
    Wait, you have a road hazard warrantee pamphlet in the car when you bought it, and they say you have no road hazard coverage?
    I'd call your consumer affairs department and then look into small claims court.
  13. galaxee
    9,810
    471
    MD
    this is an indicator i should go back and edit an FYI tag on the top of that post. hmm.
  14. DaveSheremata
    249
    Arlington, Virginia
    Cool! :) Thanks for the info. So, can you actually see what the pressures are on the MFD?
    Dave
  15. AlphaTeam
    AlphaTeam Member
    643
    Earth
    No no pressure on the MFD
  16. AlphaTeam
    AlphaTeam Member
    643
    Earth
    Good call. I just called them and they are "going to get back to me". So we will see, but I don't want to let it rest. The salesman did offer it as a selling point and hype it BEFORE I purchased it.
  17. flynz4
    flynz4 Member
    332
    Portland, OR
    2015 Prius v wagon
    Page 29 of the 2006 Pocket Reference Guide says:
    24-Hour Roadside Assistance
    Complimentary Roadside Assistance for
    3 years/36,000 miles. Ask your dealer for details.
    Prius 24-Hour Roadside Assistance includes:
    Towing for mechanical breakdown and jump start
    12V battery only
    Toll-free number, 24-hours, 7 days a week
    Lockout protection
    Flat tire changes
    Fluid delivery
    Road hazard
    Concierge service
    Mechanical first aid
    Toyota Prius Roadside Assistance
    1-877-304-6495
  18. KTPhil
    1,379
    22
    "Roadside Assistance" and "Road Hazard Coverage" are two different things.
    The former has apaprently been discontinued for 2006. It covered all types of breakdowns, not just tires.
    The latter is a tire warrantee only, and I have not heard about it being discontinued. This is what should have gotten you a new tire (perhaps prorated--check the fine print for details).
    These should have two separate pamphlets.
  19. akrca4
    akrca4 Junior Member
    26
    Is Tire Pressure Monitoring system standard on all model of Prius? I have package#1 by have the TPM reset button under my steering column.
  20. galaxee
    9,810
    471
    MD
    TPMS is now required by the Feds on all 06 and newer cars.
