Advice on Prius OEM 17" Rims
Discussion in 'Gen 3 Prius Accessories and Modifications' started by FUUFNF, Jul 31, 2012.
  1. FUUFNF
    FUUFNF Forum Lurker
    210
    30
    Long Beach, CA
    Oh, another observation between the 17s and the 15s... You REALLY feel those potholes with the 17s. And that's kinda one of the reasons I was asking about tire pressure. I wanted to make sure mine weren't set too low, because I'd really hate to bend up a rim on a pothole.
  2. ockevin
    ockevin Active Member
    493
    148
    Orange County
    gotta avoid the potholes...I have had big rims for over 10 year and never bent one or even curb rashed. I just have to watch where I am going...
  3. FUUFNF
    FUUFNF Forum Lurker
    210
    30
    Long Beach, CA
    I'm new to low profile tires, but I've always been very careful with curbs, curb cuts, and parking blocks. Those things are pretty easy to avoid. And for the most part, I avoid the potholes whenever possible. But sometimes (especially in LA) you just can't avoid them without swerving into another lane - which, obviously, could result in something much worse.
  4. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Load tables will determine the amount of pressure needed to support a given load. Depending on the load carrying capacity of the 17" tires, less pressure may be needed to achieve the same load carrying capabilities as the 15" tire.
  5. priusenvious1
    priusenvious1 Member
    325
    37
    LA
    I like this setup. I would consider doing the same if anyone is selling their 17's
  6. priusenvious1
    325
    37
    LA
    Where did you get the 17's??
