Looking for definitive answer to iPhone with non-nav 2010 Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by zm15, Dec 11, 2012.
  1. zm15
    zm15 Junior Member
    73
    So i have an iPhone 5, and an currently seeking a way to do playback in my car. Right now I'm using the 3.5mm headphone jack but I have to crank up the stereo to 25+ on the freeway to get a decent volume so i want to use the line level signal from the lightning port.
    I have the non-nav JBL audio system and was wondering if there was a way to either install a USB port for audio, or another alternative to connect the iphone. I can't seem to find a solid answer.
    Thanks!
  2. eric1234
    eric1234 Active Member
    391
    200
    Hamden, CT
    I've tried looking for this before, and the answer I've always found was - unfortunately - no.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    How high do you have the iPhone 5's volume turned up to?
  4. eric1234
    391
    200
    Hamden, CT
    well, I bought (from Amazon, I believe) an adaptor that both charged and received audio via the 30 pin connector (it's an iPhone 4). So, it's actually "line level" from the phone.
  5. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
  6. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Have you tried increasing the volume on the iPhone?
    With the pre-lightning port iPhones, there were adapters sold that allowed you to use the line level signal connected to a 3.5mm plug, but I'm not sure if any are available for the lightning port yet. You might want to search the web, including places like Belkin, Monster Cable, etc.
  7. zm15
    zm15 Junior Member
    73
    It's up all the way.
    I have a 30 pin to 3.5mm cable that I used with an old iPod and that worked great. I know they sell lightning to 30 pin, so i'd have to go from that to 30 pin to 3.5mm. Gotta love the daisy chaining!!
