2012 Prius daytime running lights
Discussion in 'Gen 3 Prius Accessories and Modifications' started by attyjeff, Dec 28, 2012.
  1. attyjeff
    attyjeff Member
    153
    40
    Is there anyway to keep them on when you turn the headlights on? I realize I can hard wire them to come on, I have done this with a few cars but I am new to this Prius thing only owned this carwith for 2you weeks.
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    No, not stock. The led daytime running lights turn off with the headlights.
  3. attyjeff
    attyjeff Member
    153
    40
    Sorry for the spelling I'm on my phone and my fat fingers or auto correct helped me type.
  4. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Haha, no problem, it happens to all of us using these damned phones, tablets etc one time or another.
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    IMO they are too bright to be ran at night. It's a bit blinding for oncoming traffic.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    The only way Is to re-wire them
  7. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    You can rewire the DRLs to auto dim when hooked up to a low beam headlight or parking light wire.
    Sketched something up quick and dirty:
    I'm not an electrical engineer, so I don't know what the resistor value needs to be to get a voltage drop across the DRLs LEDs to achieve a 30 to 50% dimming when the low beam/parking light control wire is activated.
    Disclaimer:
    If you try this, do so at your own risk. I am not responsible if you blow up or damage your Prius in any way.
    Edit: Some of the ratings on the fuses, relays, and wiring is most likely high for this application. I modified a diagram I already had from my high beam DRL mod which uses 65w 9005 bulbs, so the LED DRLs would use a lot less current/amps.
  8. attyjeff
    attyjeff Member
    153
    40
    Thanks for your thoughts
  9. Ridder
    Ridder Member
    141
    51
    Netherlands
    Here in the EU you cannot have the DRL's on, when the head/parking lights are on.
    When you turn on the head/parking lights they either dim or are turned off.
    That is the case with OEM DRL's as well as with aftermarket DRL's.
    I ordered a set of Philips Daylightguide DRL's yesterday.
    Philips - LED DayLightGuide Daytime Running Light LED solutions DRL 12V 6W - 12825WLEDX1 - DayLight - Car lights - Lighting
    They dim when you turn on the head/parking lights. Like the DRL 5 and 8 I think....only the DRL 4 doesn't dim, but is switched off.
    PriSur likes this.
  10. Adam Leibovitch
    498
    102
    They are way too bright and angled too high to have them on at night.
  11. Ridder
    Ridder Member
    141
    51
    Netherlands
    That's why they dim when you (or the "auto on") turn on the lights...and why they are called DRL's
  12. Psher80
    Psher80 New Member
    Upland, California
    so how do i get someone to do this for me on my 2013 prius?
  13. LeoArt
    LeoArt Junior Member
    32
    San Francisco Bay Area
    I believe I saw a new plug-in the other night that had the LED DRLs on at night with the headlights. Does anyone know if Toyota has enabled this, possibly by dimming or changing the angle? It could have been a mod, but I can't see that many people doing it, but I would like to have it, just like all those Audis, BMWs and others have... still seems silly to have them shut off when I turn the headlights on. Cheaper than adding some fogs to the base plug-in too.
  14. Fong
    Fong Member
    85
    32
    Arizona
    Has anyone successfully completed this mod yet?
  15. Ridder
    Ridder Member
    141
    51
    Netherlands
    The Philips Daylightguide dim from 6W to 1W when you switch the headlights in.
  16. 4everS2K
    4everS2K Junior Member
    Los Angeles
    I want my standard DRL to dim like your philips!!!:)
  17. jono400
    jono400 New Member
    29
    Would love to see them on your car once fitted, where are you going to have them located ? what length are these ones you ordered ?
  18. Fong
    Fong Member
    85
    32
    Arizona
    Like this!
  19. Ridder
    Ridder Member
    141
    51
    Netherlands
    I have some pics.....let's see if I can attach them....
    They are brighter than what they look like on the pic.
    What Fong has, is not allowed here.
    You can have DRL's or parking/marking lights, but not both at the same time.
    When you turn on your headlights, then you can have dimmed DRL's at the same time, that act as parking/marking lights, but you can't have dimmed DRL's and parking/marking lights at the same time.
    The dimensions of the Philips DayLightGuides are the same as the Philips DRL 8....
  20. samuraisd
    samuraisd Junior Member
    28
    Ok Fong, tell us how you did it. You have both on (Headlights + DRL)!
