Discussion in 'Gen 2 Prius Accessories & Modifications' started by patsy5321, Jan 4, 2013.
  1. patsy5321
    patsy5321 Junior Member
    Northbrook, IL
    Head light fades and goes out. Dealer wants $300 to replace! Where can I get it done cheaper.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Do you have HIDs?
    If so, Philips D4R Xenon HID Headlight Bulb, Pack of 1 : Amazon.com : Automotive directly from Amazon (not a 3rd party seller) I think should be a safe bet. Amazon's listed at Philips Car lights, Lighting under Where to buy.
    There a whole bunch of DIY threads here on it, but I warn you, it may not be easy w/o removing the front bumper cover. For me, the metal clip came off and I couldn't get it back on blindly w/so little room so I had to eventually remove the cover. :(
  3. Unleashd
    Unleashd Junior Member
    71
    Oakhill, VA
    Changing bulbs is not fun on the Prius. The safest route is to take the entire bumper off the front and then remove the headlight to change the bulb. Some folks have also successfully changed bulbs without taking the bumper off, but it is a bit tough. There are may threads and youtube videos to walk you through both these procedures.
    If you are handy with tools, you could DIY a good HID projector kit. I am not talking about the cheap conversion kits. I just (in the last 30 minutes) finished a retrofit. Details are in this thread. One of the best threads on a full kit retrofit is in this thread.
