Are there any differences between 2013 Prius two and 2012 Prius two? I did a side-by-side comparison of the two and all the specs were identical. I am looking to buy a Prius two, hence the question..Thanks!
There are no significant, if any changes between 12 and 13. I think some of the packages may have been shuffled around a bit but they are for all intent and purpose the same.
If the 2013 is only $400 more, it would make sense to go for one of those because the same car one model year newer will be worth more than that $400 "more" than the year-older version for years to come. What makes the choice tougher is that it's not only $400 more, factoring in the savings on the otherwise identical 2012, which should be at least $3,000 at this point. Question being how much will they discount a '13?
