Has anyone deactivated the beeping noise when...
Discussion in 'Gen 2 Prius Main Forum' started by StarBrite310, Jan 22, 2006.
  1. StarBrite310
    StarBrite310 ~ * ~ * ~ * ~ * ~ * ~
    335
    It's mighty annoying IMO <_<
  2. benighted
    benighted New Member
    530
    Westport, WA
  3. StarBrite310
    335
    I would be nervous to try all that on my own. I think I will have my salesman help me with it.
  4. tracysbeans
    tracysbeans Member
    979
    Wisconsin
    Would they help with it though? I would think they wouldn't since they added it as a safety feature?
    I would just like to be able to disable to passengers seat belt. If I put something heavy on the passengers seat the seat belt alarm goes off. <_<
  5. tracysbeans
    tracysbeans Member
    979
    Wisconsin
    Starbite, When I can I see your pics? I wanna see your seats!
  6. benighted
    530
    Westport, WA
    You can disconnect the wire that goes to that seat belt. Just look under the seat for the wire going to the connector, you will see that it has a connector you can just pull out, it won't beep anymore.
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    It's easy, click the YES in benighted's post above which is for the reverse beeper. If you read the "additional note" at the bottom of the directions you will see it is also for the seatbelt beepers, either seat depending on which belt you buckle/unbuckle.
    StarBrite, if you are uncomfortable doing this and the dealer won't help you get one of your "techno geek" friends. I really don't think you can mess anything up by trying it yourself though. You may be able to do more than you think you can.
  8. StarBrite310
    335
    Haha I will be posting them tomorrow!!! Look for my post in the early afternoon. :D
  9. Godiva
    Godiva AmeriKan Citizen
    10,339
    Yes.
    But then I installed a beeper in the back left taillight so it can be heard both outside AND inside.
    Had to do it. My Mom freaked so often when I backed out of the driveway it was the only way to shut her up.
  10. agile pagile
    agile pagile New Member
    46
    Benicia, Ca
    Tracy do you read over your posts before you add them? You really should cause maybe you will be better understood. What the hell are you trying to say or are you really into this dumb blond stuff. Well you sure have me fooled.
  11. tracysbeans
    tracysbeans Member
    979
    Wisconsin
  12. Mystery Squid
    Mystery Squid Junior Member
    Dude, this is an internet message board... Not an Expository Writing class at Yale. A lot of people post from the seat-of-their-pants, as I do sometimes, no biggie, as long as the point gets across...
    Plus she's got some legit questions I'm interested in reading about.
  13. Spunky
    Spunky New Member
    469
    At first I found the reverse beep annoying but now I'm used to it. Plus it's saved me plowing forward into the garage wall a couple of times. I've flipped the gear shift, looked into the rear view mirror and realized the blasted beeper wasn't beeping. Checked the display. Whadda ya know? Still in drive.
    There might be a legal issue as well. Bet a Prius' computer keeps all settings in memory. A dealer would be able to tell if the reverse beeper was turned off when the car was driven up over the car parked in front of it.
    That does happen, really!
  14. benighted
    530
    Westport, WA
    I always look at the gear indicator before moving because sometimes it doesn't take the gear if you shift too soon or too quickly.
  15. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    Just disabled mine tonight (thanks to this thread). Ah, so much quieter now! The backup camera is a pretty big hint to which "gear" I'm in, so I don't think I'll miss the beep.
  16. Kathleen2
    Kathleen2 New Member
    77
    I would like to know how to install a beeper so it can be heard on the outside and inside. Please tell me how to do this. (Make it easy, I'm old and slow.)
    Kathleen
  17. aka007ii
    aka007ii New Member
    482
    Santa Clarita, CA
    I could disable it for you. Did mine just fine.
  18. Godiva
    10,339
    I wrote up some directions. These are based on other directions from other Priuschat posters. I put them together, added more explanation and pictures.
    How to install a backup beeper.
  19. TidelandTravis
    TidelandTravis New Member
    58
    Los Angeles, CA (Thousand Oaks)
    Damn, I wish I was closer to Santa Clarita so you could do it for me (terrfied of f$%@ing up the car or warranty)... My clients think I'm driving a school bus everytime I back out of a driveway. I have to let them know that it's only inside the car so I don't seem like a total douche.
  20. Kathleen2
    77
