Mysterious Beep while shutting off car
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DeeSeven, Jan 21, 2013.
  1. DeeSeven
    DeeSeven New Member
    Hello,
    I have a 08 prius and every now and then when I shut off the car I hear the tiniest little beep and I can't figure out what it is. It isn't my FOB as I've already had that beep :D and fixed it over the summer. It has been going off and on for the last 2-3 months, I can't make it happen on purpose so the dealership thinks I'm losing my mind and no its not my cell phone beeping either lol it is definitely the prius beeping
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
  3. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    check the 12v battery. Check in the morning before starting. I use a multi meter and like to see 12v +. If below12v then replace it asp. H
