Make sure you practice opening the jumper port in the fuse box
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tankyuong, Jan 21, 2013.
  1. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    It's quite a challenge if you have never done it before.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Did you have to or just practice?
  3. tankyuong
    1,555
    661
    Central MO
    Battery tender hookup
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Am I missing something here, what is the challenge?
  5. tankyuong
    1,555
    661
    Central MO
    You have to open the door to access the positive terminal and there s a trick to it
  6. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Hum, you are going to make me go open mine again and see what you are talking about. I just do not remember it being difficult or tricky.
  7. hlunde
    hlunde Member
    419
    75
    What I have noticed is that the distance from the fuse-box terminal to the designated ground point is further than some (inexpensive) jump packs can span. This should be no big deal, but there's a lot of plastic coverings that make it difficult to get to an alternative ground point.
  8. Mendel Leisk
    41,287
    As long as you have a flashlight it's pretty easy to figure out. Just going by feel I'll sometimes have troubles: guessing wrong as to which side has the locking bit, which way to push it. I have as much trouble getting the fuse box cover to snap back on securely, with all the little hooks engaged. Remember at the dealership, when they were dealing with our dead 12 volt (car sat on the lot a long while), they didn't get it right either.
  9. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I finally got around to checking my 12V jump terminal cover last night. It was still light outside so I was able to see well.
    With plenty of light it was quite obvious to me that the cover was hinged on the right hand side so you would have to release it on the left hand side. The release latch was easy to see and release. Granted I have done this before to check the 12V battery voltage with a meter so I was familiar with this.
    The OP does make a valid point that if you have not done this before it is a good idea to do this before you really need to do this. Without adequate lighting I could easily see where it might be difficult to find the release latch.
    tankyuong likes this.
  10. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    When I installed a louder horn I had to run a wire to that box. I do not recall it being hard to open.
  11. Mendel Leisk
    41,287
    ^ It's not hard to open. Just a mite tricky to close, to get all the latches engaged properly.
    And not really difficult, hey: this is a trivial difficulties thread, didn't you know. ;)
  12. tankyuong
    1,555
    661
    Central MO
    It takes me 2 small screwdrivers to disengage the clips before loosening the door by pulling up on the door and swinging it open,imagine doing that on a cold night
  13. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Are you referring to the door over the 12V jump point or the fusebox cover? I opened my fusebox cover and the jump point cover using only my fingers. It was like 36 degrees when I did this.
    I guess I am confused by your difficulty.
  14. Judgeless
    1,821
    257
    Cleveland, OH
    There is no way we are talking about the same thing. I just went in the garage and opened with one hand while holding my cell phone in the other. It takes seconds. No tools needed. Is this what you are talking about? Or is it something else?
    In the video I point to the cable I installed for the louder horn.
  15. tankyuong
    1,555
    661
    Central MO
    I'm talking about the cover that covers the positive bolt used for jumping your car in case your battery is dead, its inside the fuse cover.Now try a different video showing that.
  16. Judgeless
    1,821
    257
    Cleveland, OH
    It takes you 2 small screwdrivers to do this?
  17. RRxing
    RRxing Senior Member
    2,542
    1,817
    NEPA
    So simple, and with "Our Lips Are Sealed" by The Go-Go's on in the background... (y)
  18. Judgeless
    1,821
    257
    Cleveland, OH
    I always have a music on in the garage. 24x7
  19. tankyuong
    1,555
    661
    Central MO
    Your prius fuse box is different than mine what gen is yours 2
  20. Judgeless
    1,821
    257
    Cleveland, OH
    I have a 2010 Prius 4 from the USA. It is a Gen III
