HHO KITS? What are they and do they work on a prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Steven Harvey, Jan 10, 2013.
  1. Steven Harvey
    Steven Harvey Junior Member
    96
    Guelph On. Canada
    Hello everybody, I am new here and would like to start off by introducing myself. My name is Steve and I am a prius-oholic. I just bought a 2006 pruis. and I have alot of questions on how to make the car more sustainable.
    Basically wondering if HHO (Oxyhydrogen) systems actually do alot for fuel economy and if anyone has tried this on a Prius.
    Thx,
    Steve
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    They almost work as well as "snake oil" but snake oil works a little bit better.
    dogfriend, Blu-ray, F8L and 1 other person like this.
  3. Steven Harvey
    96
    Guelph On. Canada
    Ok, I am currently running snake oil in my prius so i will just stick with that. lol thanks usnavystgc.
    usnavystgc likes this.
  4. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    I,m on the fence with this one. I'm not sure which one is best.
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    you guys should understand that comments like this is why people leave priuschat all the time for more informative forums.... leave responses to those willing to try or have tried... just my .02
    Daves09prius likes this.
  6. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    yes. tell us what it is, what it does, and why it's inferior to snake oil.
  7. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
  8. V8Cobrakid
    3,790
    152
    there are only a few people i know who are willing to risk the chance of hydro locking their engine (too much hydrogen will not compress when needed and could cause damage).... HHO isn't really supposed to be a fuel only... it's more of an additive to help take up the "excess" room inside a cylinder of a larger engine (like the f150 i've seen it in)... therefore leaning out the fuel mixture. in a car like ours, where we use extremely small amounts of fuel anyway, it's hard to add anything to the mix without risking the whole hydro lock scenario. the f150 i've seen did get better fuel economy... but you have to constantly monitor the system in many ways... so the guys ford i've seen could end up being a "Found On the Road Dead" scenario without extra care....
    example for our car... at 60mph, our fuel consumptions is somewhat equivalent to having a bead of water run from the tap that splits into drops somewhere around 6 or so inches away.. and that's our car on a bad day. larger vehicles like an f150 consumes fuel equal to a stream that doesn't bead at all... even on it's best day.
    i don't take mythbusters serious on anything. there have been a few test i've seen them do and re do, where they botch the test because they are not pros in most of the fields they test.
    in the end you're probably better off adding a turbo. I've chatting with a guy who has done this and does extreme prius mods (know of the prius limo?)... he used to be on this forum but left because everyone here whines like little girls, and ill educated people like to chime in on things they have no clue about... usually jumping the gun to shoot down theories. (if it wasn't for crazy ideas, we wouldn't have hybrids or electric vehicles because everyone always thought it wasn't feasible.... now it is, for a price... but the cheepos still complain)
  9. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    Here's the good thing about threads like these. It gives a place for the scientifically illiterate folks to out themselves.
    No offense, folks, but this should be a lesson that you shouldn't believe everything you hear. If it sounds complicated, it might be total BS.
    ftl likes this.
  10. V8Cobrakid
    3,790
    152
    i've seen the system work.
    unfortunately the plates he used corrode rather quickly, so he spent a lot of time re building and arranging plates.
    you can take your comment (and "like" for that matter) and shove it
  11. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    I've never seen any rigorous testing indicating it works, or at least that it's any better than water injection, which has it's own set of problems.
  12. V8Cobrakid
    3,790
    152
    It's definitely finicky and has its own problems. I'd rather add a turbo to be honest. (I know a guy with a turbo genII) The problems my old acquaintance went through with HHO was mind numbing at times... And dangerous
    I'd rather not quote details unless I have them down 100 percent. (At least 90)... So I refuse to share details that I've seen... besides the bits I've tossed out already... If you can even call them details (all I've really said is plates and additive compared to true fuel)
  13. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    Ohh.... I think I know what he's doing Al and lye, or some variant of that. Not really what most proponents of HHO claim, but still valid, like running your car on methane from trash or whatever. Having said that, I've never seen a valid HHO set-up, as in one that just splits water to make H2 and somehow increases energy efficiency.
  14. maestro8
    471
    109
    nor cal
    Stay classy.
    A long winded way of saying "I've got nothin'".
    ftl likes this.
  15. V8Cobrakid
    3,790
    152
    In reality, I can't break it down because I'm not the one with a patent pending on it. For me to even start going into details of someone else's discovery is illegal. I helped him create the CAD drawing for a more reliable milled plates instead off "off the shelf material"
    I can say its somewhat similar to the aluminum/lye concept but its smaller and in the engine bay.
    Apparently roflwaffle is smarter than you since he/she (don't want to assume anything) can look up concepts and relate instead of crying "snake oil" at anything you don't understand.
    I'm one classy B. don't forget it. Haha
    (Funnier to me since I'm a guy)
  16. usnavystgc
    3,159
    990
    Tucson, AZ
    I've always said "If you have to tell someone you're classy, then you may want to examine your definition of "classy"".
    Britprius likes this.
  17. Britprius
    5,194
    1,922
    The problem with this sort of device the gains versus the losses.
    I will agree that hydrogen and oxygen fed into a petrol engine will improve economy (give out power).
    The problem arises that it takes as much power to produce HHO from water by passing a current through it as it produces when it is burnt add the losses of the Prius engine drive train and generators and it falls flat.
    If we could brake down water that efficiently we would have no need for petrol.
    John (britprius)
    babybird and usnavystgc like this.
  18. usnavystgc
    3,159
    990
    Tucson, AZ
    For sure John. I've been hearing about HHO kits since the 1980's (and perpetual motion motors as well). The net result is always either an overall loss or zero gain. I have to agree with you and maestro8 on this one. If there were gains to be had, auto manufacturers would be all over this (as it would give them a competitive advantage).
    In God I trust, all others must provide proof.
  19. V8Cobrakid
    3,790
    152
    The classy comment is a joke of sorts.
    There is a gain with his system. The fallback is the consumption and maintenance of the system itself.
    Diesel is more efficient than petrol but not every car in the road uses diesel.
    Turbo has its gains here and there over non turbo, but its only recently that car companies are making the turbo a semi standard option.
    It's the maintenance of the system. Even though his system worked, its a pain to maintain it and rebuild it all the time.
    So in the end, there is a loss... Of your sanity from reworking it all the time.
  20. Britprius
    5,194
    1,922
    I think you are getting confused with the term efficient.
    Diesel is not more efficient than petrol, they are two different fuels.
    Diesel has more calories than petrol so gives out more energy per unit when it is burnt.
    A turbo gets more air into an engine and that extra air requires extra fuel making an engine give out more power than a naturally aspirated engine because it is burning more fuel and air, some pumping losses may be reduced but this is marginal.
    John (Britprius)
