How do you change the License LED? Getting Access seems very difficult!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by arek, Jan 5, 2013.
  1. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    where do you buy led for 2 bucks for both?
  2. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    The LED's I bought (pictured in post # 18) are whiter and brighter than the 5w incandescent wedge bulbs they replaced. When swapping the bulbs out I did one side- turned the lights on then did the other side- that's how I know the LED's are brighter and whiter than the incandescent bulbs- I had them running side-by-side for a few minutes. If the LED's were dimmer- I wouldn't have used them.
    As to why replace license plate bulbs with LED's? I just dislike filament based lighting (including florescent) overall, so where practical and inexpensive- I replace 100+ year old tech with LED's.
    Next up is replacing the pathetic excuse for a bulb (mini-festoon 30mm x 10mm) they use in the cargo area of the PIP with a nice bright LED.
  3. lopgok
    lopgok Member
    177
    30
    unknown
  4. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    Be careful when pulling out the bulbs from the hole if you don't unplug the wires first. I noticed when doing mine if I'm not careful and touch metal around it there is a slight charge in there for some reason. Be VERY careful when putting the LED in if they are not in a housing of some sort. You could end up shorting the bulb. AND YES the power was off to the license plate lights when I did it. However, I think I should have unclipped the power wires first and then removed the bulb socket from the hole. :eek:
  5. kmkremer
    kmkremer Member
    227
    30
    San Diego
