what's the "p" button for?
Discussion in 'Gen 2 Prius Main Forum' started by elroy munson, Jan 29, 2013.
  1. elroy munson
    elroy munson Junior Member
    I use the rectangular "p" button but have no idea of what is does.
    Power? Parking?
  2. El Dobro
    El Dobro A Member
    7,086
    3,263
    Puts the transmission in park.
  3. richard schumacher
    7,664
    1,046
    United States
    What's this rectangle made of sheets of paper that says "Owner's Manual" on one side? :_>
  4. PriusNP
    PriusNP Junior Member
    85
    17
  5. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    PRND is an automotive acronym, on the Prius the P is near R as it should be.
  7. JPP
    JPP Junior Member
    26
    P= Pickles, it turns on the pickle dispenser.
    PriusGuy32 likes this.
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Just a note:
    Toyota is legally required to have a P, and an N, and a B, (although it did not have to be named B) But you may never need to use any of them.
    If you hit Power, it automatically puts your car in P.
    The Prius cannot do regenerative braking, nor charge the HV Battery in N.
    B is useful for long downhills, where the regenerative brakes will fill up, you can use B from the top to help keep your friction brakes cool.
  9. cyberpriusII
    1,155
    1,763
    Mars Hotel
    I still put my car in P before I hit power.....why, 'cause the official, obtuse manual tells me so....
  10. PriusGuy32
    1,417
    514
    Has it ever dispensed a pickle?
  11. uart
    uart Senior Member
    4,220
    1,210
    Australia
    I've heard that it really will dispense a pickle, but you have to get it into "hybrid stage 5c" before that function is available.:cool:
    dorunron, PriusGuy32 and GrumpyCabbie like this.
  12. romad
    romad 2004 Prīus Base Former Owner (Sold 13 May 22)
    320
    57
    Prescott, AZ
    Unfortunately, leaving the car in Neutral for more than a few minutes without the ICE running drains the battery very fast. I've gone to a car wash with full bars and by the time I'm out the other side, I'm down to 2 or 1 bar(s).
    Re the "B": where does it say it is required? Park, Reverse, Neutral, Drive make sense, but I've never had a "B" position on my other cars.
  13. cablesm
    cablesm New Member
    B = engine braking. It will combine regenerative braking (unless the battery is full) with a sort-of low gear behavior, spinning the engine fast against a closed throttle without giving it gas. This slows the car without using the friction brakes, and can work even when the battery is full. I've seen it called "L" (for "Low") on other automatic cars, and on manual cars you just shift into a lower gear...
  14. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Standard No. 102; Transmission shift position sequence starter interlock, and transmission braking effect. - Federal Motor Carrier Safety Administration
    Usually that would be labeled L, but someone at Toyota was too honest, B does not use lower gearing.
  15. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Can you legally drive? If so, let me know where you live and I'll avoid the area :)
  16. craigk
    craigk Member
    139
    Golden Valley, MN
    Years ago in drivers ed class someone said a student put the car in "P" to pass! I still feel bad for that kid, hope it wasn't true.
  17. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    That kid probably came from the same class that said R was for race and D for drag. ;)
    GrumpyCabbie likes this.
  18. romad
    320
    57
    Prescott, AZ
    Interesting. In automatic transmission cars, I've never used any positions other than PRND. I figure the other positions (L, 1, 2, etc.) were for those who wanted to pretend they had a manual!
  19. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    You might find some occasions for B (or L in some other car) if you drove to Sattley CA and back on 49, the Golden Chain.
  20. romad
    320
    57
    Prescott, AZ
    That's the section of CA 49 between CA 89 and Nevada City. Sometime back in the 90s I took my Miata through there; one of these days I'll have to do it again. But it really isn't a road for automatics, IIRC.
