Is Too Much EV A Bad Thing?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by REmmons, Jan 31, 2013.
  1. REmmons
    REmmons New Member
    Richmond, VA
    So recently I was provided an outlet at work to charge my PiP. I have a pretty short commute, right around 8 miles one way. And now that I can charge on both ends of the commute, I could drive the PiP all EV for majority of the time.
    Is this a good thing to do? Do the electric motors last as long as their ICE counterparts? I know that the ICE kicks on if it hasn't run in a certain amount of time or miles but if I'm running 95% EV will this have an adverse effect on the life of the car? Or could I still expect to get 100k+ miles on it?
    #firstworldproblems
  2. El Dobro
    El Dobro A Member
    7,074
    3,258
    I wouldn't worry about it. The car pretty much takes care of itself as it's designed to do.
  3. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Charge as much as you can, drive and enjoy, not an issue.
    lensovet likes this.
  4. Zythryn
    Zythryn Senior Member
    6,405
    4,402
    Generally electric motors will last much longer than ICE engines (one moving part as opposed to hundreds).
    But the true answer to you question is, it depends why you want to drive electric.
    Is it for GHG emissions? If so, what GHG emissions result from gas vs electricity in your case?
    Is it for costs? What does electricity cost in your area vs gas?
    Is it to reduce the nations trade deficit? Electricity definitely.
    Is it to reduce the pressure on our military to keep volatile oil producing parts of the world 'calm' by putting our soldiers in harms way? Electricity all the way.
    lensovet, DadofHedgehog and JMD like this.
  5. john1701a
    john1701a Prius Guru
    12,794
    5,276
    57
    First, the electric motors themselves should outlast the combustion engine by a significant amount. They are quite robust and have far fewer parts to break or wear out.
    Second, it's the battery that ages the EV part. The best thing you can do for it is avoid high-temperature exposure, avoid continious high-power draw, and allow for a cold-soak (rest time) between recharges.
    I recharge at work too. Mid-Afternoon is when I plug in. That allows several hours for that cold-soak and makes a nice excuse for a break outside.
  6. REmmons
    REmmons New Member
    Richmond, VA
    All of the above! Sounds like electric is the way to go.
  7. Gaudete
    Gaudete Junior Member
    71
    I agree with everything that's been said so far.
    Allow me to add: unless I misunderstand how the car works, the electric motor is pretty much running all the time.
    The only question (I thinki) is to what degree the ICE needs to kick in to provide additional power.
  8. 3PriusMike
    3,089
    2,411
    Silicon Valley
    Yes, because of the way the power split device works in the Prius you have one ICE and two motor generators. The shafts of the two MGs are pretty much always rotating. And when the ICE isn't firing the speed ratios of the two MGs cause the ICE to not be rotating (except when the ground speed exceeds ~42 mph) and the ECU chooses to make the ICE rotate. The excitation voltage, applied by the ECU to each MG determines whether the rotation makes it a motor or a generator...or just a spinning hunk of metal (neutral).
    Mike
  9. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    I have a standard Prius but PIP is on my radar. From a previous post, gasoline can get stale so you want to burn a little gasoline. You may be doing that to warm up the PIP or get heat in the cabin. I believe you should empty a gas tank every 6 months so a periodic long drive may do the trick. Just a precaution. Your owners Manuel will have the info or one of the PIP drivers can explain better.
    I thought the EV can work up to 62 MPH.
  10. retired4999
    2,652
    625
    Eau Claire, Wi.
    Notice about fuel
    For plug-in hybrid vehicles, fuel may remain in the tank for a long time and
    undergo changes in quality depending on the how the vehicle is used.
    Refuel at least 5.3 gal.(20 L, 4.4 lmp.gal.) of fuel every 6 months (refuel a
    total of at least 5.3 gal. [20 L, 4.4 Imp.gal.] over a 6-month period), as this
    may affect components of the fuel system or the gasoline engine.
    You are correct. :)
    JMD likes this.
  11. JMD
    3,779
    1,282
    Thx. Very important to know.
  12. retired4999
    2,652
    625
    Eau Claire, Wi.
    :D Your welcome!
  13. El Dobro
    El Dobro A Member
    7,074
    3,258
    The engine turns on after so many miles to circulate the fuel.
  14. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    You'll end using gas on other trips.
    Electric motors last a high number of miles.
    Just please don't think of the charging at work during the day as free. It's not. In fact it's much more costly than charging at night. So, please try to charge at work as little as possible. And when trying to figure out when to charge, just look at your area's time of use tariffs. Try to avoid peak, as all you'll do is help make electricty more expensive by adding to peak demand and increasing the required capacity. Off-peak is much cheaperbecause capacity is under-utilized. That difference in price indicates just how costly underutilization is.
  15. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    You can always add Stabile gas treatment or Seaform to the tank. I been using Seaform in my gensets, mowers, snowblowers, and motorcycles. In storage for 4 - 6 months. When Time comes to power up, no gasoline separation issues.
    DBCassidy
  16. retired4999
    2,652
    625
    Eau Claire, Wi.
    I just copyed what was in owners manual. :)
    JMD likes this.
  17. bisco
    51,037
    my commute is 7.5 miles each way. my current ev/hv ratio is 80/20, 400 miles ev and 100 hv. sure the batteries will degrade a bit faster. enjoy! we'll cross that bridge when we come to it.:)
    retired4999 and JMD like this.
  18. 3PriusMike
    3,089
    2,411
    Silicon Valley
    Charging in the summer in the afternoon is the "costly" option. This increases the summer peak and is how peak demand estimations are done. IMO, charging at work in the winter is not more costly.
    Mike
  19. bisco
    51,037
    we don't have any off peak rates here.
  20. john1701a
    12,794
    5,276
    57
    The ramp where I park & recharge has a large (82 kWh) solar-array.
    That alters the circumstances of the summer afternoon cost. :)
