Finally did a full paint correction and Opti Coat on the Gen2
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by drew935, Feb 4, 2013.
  1. drew935
    drew935 Member
    168
    Nor Cal
    Some pics for now. She used to like having the dealerships wash the car after it was serviced under warranty before I started detailing cars. So all of the damage was created by them.​
    Full write-up on my portfolio site. ;)
    Starting with the wash and decon
    Swirls and marring in the paint. Hood before
    After
    Fender before
    After
    Driver's door before
    After
    Rear door before
    After
    Windor visors to be corrected as well
    Marring on the roof pillars
    Roof before
    After
    Qtr panel area before
    Corrected
    Tails before
    Corrected
    License plate area
    Upper half
    After
    Right qtr panel
    Corrected
    Right side roof pillar
    Corrected
    Right side of roof
    Right rear door
    Corrected
    Pass fender
    After
    50/50 of the trim dressed
    Wheel well covers gets dressed as well
    After Opti Coat. Grill is dressed as well
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Nice. How do you get it to not have hazing like the second picture?
  3. drew935
    drew935 Member
    168
    Nor Cal
    Thanks!
    The second pic shows swirls done by the dealership. Hazing looks a lot different.
    The paint is corrected with a DA polisher.
  4. edthefox5
    10,096
    4,834
    Clearwater, Florida
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    awesome. it's not all that expensive either, from what i can find.
    question... how long is the actual cure time?
  6. drew935
    drew935 Member
    168
    Nor Cal
    Fully cured in 30-60 days depending upon the temps.
    After 24hrs, it can get wet, and can be washed after a week.
    Even though the Opti Coat is not that expensive, correcting the paint to ensure a defect free surface is important.
  7. V8Cobrakid
    3,790
    152
    and that's the opti coat 2... or the original?... from what i've read the opti coat two gives more work time (but same cure times and such?)
    interesting about the cure times and such... i'm going to save this data.
  8. V8Cobrakid
    3,790
    152
    btw, know of any places that do this around los angeles? (that you would trust) i'm curious to do it myself. i ask because the wife asked if she can have someone professional do it. (so it doesn't burn up a day of our/my time applying and such... a full wax job took me forever...)
  9. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    What is paint "correction"? What's to be corrected?
  10. uart
    uart Senior Member
    4,220
    1,211
    Australia
    What quantity of this "opti-coat" do you need to cover a Prius and how much does it cost?
  11. drew935
    drew935 Member
    168
    Nor Cal
    Yes, Opti Coat 2.0
    You can contact Tuan at Glossworks. He's highly experienced and I approve of his work.
    Glossworks Paint Restoration & Protection - Rosemead, CA - Car Wash & Detailing | Facebook
    Paint correction is leveling the defects in the paint like scratches, marring, swirls, and holograms.
    The syringe comes with 20ml at$69.99 and if I used about 9ml as I double covered certain areas.
    Typically, I will use 6-8ml on my client's cars.
  12. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Last pic is like my car. Tint and no wheel covers. Looks 100% better.
    That opti coat is the shizzle. Wish you lived by me.
  13. drew935
    drew935 Member
    168
    Nor Cal
