Key Fob case needed for 2006 smart entry
Discussion in 'Gen 2 Prius Main Forum' started by emosca, Feb 6, 2013.
  1. emosca
    emosca Junior Member
    The original key fob case broke next to the lock button. The fob still works. If I can get a sound case I think I can remove the electronics from my original and install it in the sound case. If you have a fob in which the electronics is broken, I would like to use it to try and salvage my fob.
  2. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    The trick for opening a Gen2 keyfob case is to insert needle nose pliers into the mechanical key slot & spread the case open. Best to remove the battery first. Clean the old glue out, and use a moderate strength glue to reseal. If you use too strong a glue, you'll never get the case open again without breaking it...
    The circuit board is just jam fit, although some of the glue may have overflowed from sealing the case. Note also that the transponder is separate from the circuit board. It's a black chip with no connections on it, fit into the bottom of the case. Gen3 doesn't have a separate transponder.
  3. emosca
    Thanks RobH. Now all I need is a sound key FOB case.
  4. RobH
    RobH Senior Member
    2,385
    991
    70
    One more thing...
    The black logo and silver logo cases are identical. If all you want is the case, either one will work. The circuit boards are the same dimensions, although the electronics are different.
  5. emosca
    Thanks again. I take it the black logo case is for the smart entry version and the silver logo case is for the standard entry case, or vice versa.
  6. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Vice versa, the silver logo keyfob is for the Prius that has the Smart Key System or as you refer to it Smart Entry.
    Ron
  7. RobH
    RobH Senior Member
    2,385
    991
    70
    Note that it's the electronics inside the keyfob that makes it SKS or non-SKS. The piece of plastic with the logo on it is interchangeable between the two types of keyfob. Having the wrong color logo is probably rare, but it could certainly be confusing.
  8. qmanqman
    qmanqman Active Member
    428
    146
    CO
    Tried this and it started to break the case. How on earth do you get these apart without destroying them?
    EDIT: Don't try cracking it through that spot. Just get a small paring knife and slowly and forcefully wedge it into the seam and pry. Do it slowly all the way around the case. The damn things are glued together.
    #8 qmanqman, Aug 8, 2025
  9. PriusTech
    PriusTech Active Member
    246
    104
    Reno
    2006 Prius Key Fob Case Smart Entry for sale | eBay
  10. Hayslayer
    Hayslayer Active Member
    390
    219
    You don't. They're glued and typically are more of a pain than just buying a new case for $10 on ebay.
    If you do replace the case, DO NOT throw away the RFID chip. It must be swapped over to the new case. No RFID chip means the slot will not function and you'll also not be able to make a duplicate key fob.
  11. highmilesgarage
    highmilesgarage Active Member
    468
    174
    Kansas City
    I don't remember they're glued, it just slides off and the bottom part with the Toyota logo can be re-used since the aftermarket usually don't have those. You can buy these covers for cheap in Amazon.
  12. dolj
    dolj Senior Member
    8,430
    4,285
    Wellington, New Zealand
    Be that as it may, they are glued together. You don't need to break them apart to change the battery; that is all accessible without any destructive force required.
    If you need to swap the RFID chip and circuit board into a new shell case, the original case must be split apart destructively.
    You do need to slide the rear cover off, which is sometimes hard to do if it hasn't been done in a long time, before attempting to separate the two halves of the case.
  13. qmanqman
    428
    146
    CO
    Thanks for the heads up. The buttons on the original case were destroyed and I did keep the the original case. I'll swap in that chip. Again thanks.
